3 threads found!
maximilianth | 16 | 283 | ||
maximilianth | 12 | 218 | ||
maximilianth | 26 | 588 |
18 comments found!
It get´s better :-) fStop value was 1,8
http://www.renderosity.com/mod/gallery/index.php?image_id=2306158§ion_id=&genre_id=&np
Thread: Poser 9 DOF doesn´t work... | Forum: Poser - OFFICIAL
Quote - I googled fstop and did some reading. The smaller the number the less DOF there is. The larger the number (up to 22) the greater it is. To focus more on the orange robot and less on the red robot use the DoF guide (crosshairs). Put them on the orange robot and use a smaller fstop setting (1 to 3). This will focus the camera on the orange robot and blurr the red one.
Thanks for the info! :)
No i want the red robot more out of focus. Because the focus is directly on the orange robot, because of this it is nicely sharp.
I think the effect would be much better if the red robot gets a little bit more unsharp than it already is.
I will try this in my next renders.
Quote - I was having problems with DOF in PP2012 too. The attached image is the result of using the DoF guide and the information from hborre about the pixel sampling. When I changed the sampling from 6 to 12 it made a huge difference. Yes, it took more time but was well worth it.
What does change if you increase the pixel sampling?
Here you can see my first render with DOF (Focus on the robot behind).
http://www.renderosity.com/mod/gallery/index.php?image_id=2305443
I think next time i will change the fStop value in the camera settings so that the objects in the foreground will be a little bit more out of focus.
What do you think?
Thank you!
With Display>Guides>Focal distance i found out the right focus distance. Now it works and looks good. But the right distance was 13800 and not 39 like the built in python script calculates...
Thread: ** Poser Staff Picks! ** | Forum: Poser - OFFICIAL
Thread: Getting the hair more realistic | Forum: Poser - OFFICIAL
For testing, i half sized the bump level. Result ist not good. With the bump level at around 0,6 the strands look much finer.
Now i´ve changed the filter from "quality" to "none" but as expected the hair gets more crispy. I think quality is the best way.
But i forgot, this screenshot above is from the original loose hair. This here is the updated touchable loose hair:
Can we change something in the anisotropic tab? Maybe it´s getting smoother with other settings?
Hey,
now i´ve buyed "Touchable" for Loose Hair:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=87596
It looks much better!
(First pic with standart mats and second with Touchable)
Thread: Colour of panties doesn´t change | Forum: Poser - OFFICIAL
Really?
I don´t have much settings under general preferences. Only "document, interface, library, render and misc"
And under each of this tabs only a few options to set...
And i can´t find the settings vor preview there...
Thank you Medzinatar!
You´re right, in render it looks like the colour i´ve choosen :-)
Where can i find the preview settings in poser 9? I can´t find this...
Hey,
thank you all for your reply!
@William_the_Bloody: Your right, the "Touchable" series looks best. But i think the hair isn´t finer than the original Loose Hair? Didn´t he changed just the colour?
@WandW: Thank you for the link. I will get a closer look to it!
@ToxicWolf: The Kirte hair looks really nice and realistic. I added it to my wishlist :-)
I also will take a look at Kozaboro hair.
