70 threads found!
mazzam | 3 | 281 | ||
mazzam | 1 | 165 | ||
mazzam | 3 | 414 | ||
mazzam | 4 | 200 | ||
mazzam | 7 | 326 | ||
mazzam | 4 | 137 | ||
mazzam | 2 | 128 | ||
mazzam | 0 | 93 |
(none)
mazzam | 9 | 260 | ||
mazzam | 0 | 135 |
(none)
mazzam | 2 | 230 | ||
mazzam | 1 | 57 | ||
mazzam | 7 | 78 | ||
mazzam | 2 | 51 | ||
mazzam | 1 | 33 |
104 comments found!
If there is any confusion about the matter she is using her fingers to fire the guns. I took great pains to make sure the fingers were touching the guns not herself. The concept of a Gatling bra is comically ridiculous. I cannot imagine it would be taken any other way.
Thread: Gallery update error 500 | Forum: Community Center
Thread: Gift certificate not accepted | Forum: Community Center
So that is the proper procedure for reporting a certificate failure? I no longer have a copy of the failed certificate and I am out 1000 points with nothing to show for it. I work hard to post high quality art. The simplest fix might be to restore the 1000 points that turned out to be useless.
Is there a safer way spending a gift certificate to a purchase page than copying and pasting which seems easy to get wrong. Besides when I copy it I get it in a tiny almost invisible font, white on black. Is there a safer way of copying and saving it? On a rank of 1 to 10 I would rank the human factors design of this system as -1 at best.
But if there is documentation of how to use the system lurking somewhere, pleas send me the link.
Thanks for your attention.
Thread: Help with stretching fabric over breasts | Forum: Poser 12
For conforming clothing select chest make a magnet for each breast. Thinking of each breast as a sphere, put each mag base at or a little behind the center of the sphere. Position and scale the mag zone to surround the breast. Then select the mag and increase scale to PUSH the garment away from the breast. You can fine tune with x y and z scale as well as the movement dials. If you get a crease under the breast select the mag go to properties and add the abdomen actor so the magnet moves that too. And you can add a magnet positioned with its base in the center of the chest to take care of the cleavage area. Remember where you place the mag base is essential because it defines the origin of the displacement field. Make a nag for each breast and use x and y ROTATION to get very realistic breast movement!
Thread: Poser 12 for Macs... is it worth the upgrade? | Forum: Poser 12
Anyone running Poser 12 on a MacBook Pro if so what configuration. Planning to run Poser 11 and 12 in parallel on two machines. Not risking legacy content with Python issues. Planning to set up scenes in Poser 11 and moving them to Poser 12 Cycles lights, materials and Superfly rendering when that is called for. Present computer stuck with old graphic card and can't accept new ones. Will be getting new Macbook anyway.
Thread: How to put punctuation marks in gallery image titles | Forum: Community Center
Your version worked fine. Input method US isn't named but has US flag icon. Hope that is the right choice.
But I am using the apostrophe and it is getting converted into that coded mess. Only happens in the title not the text. My browser is Mac Safari.
Thread: What is Going On?????????????????? | Forum: Community Center
Keep getting page not available error messages in Safari. Hope this helps identify the problem. Hint. whatever they changed recently mist be responsible for all the sickness going on
Thread: Vendor search - why so slow in the Marketplace | Forum: MarketPlace Customers
That is exactly what I am using. And when I enter the vendor name the search takes many times longer than when I am selecting a vendor when adding credits for am image in the gallery where the names come up almost immediately when I type the first two or three letters. Here I enter the first two letters and wait and wait and wait for something to come up. And often it tries to do a spelling correction on the letters I have entered which makes it impossible to enter the name I am looking for. Look at it this way. When I am in the marketplace I am not looking for the vendor as a person, which seems to be what the search is doing, I am looking for a STORE which happens to go by the name of the vendor. So what the marketplace needs is a STORE search that uses a search window that is present only in the marketplace and does not require switching modes in a search window. The number of stores is small enough so this window would have just about instantaneous response. And before the change there was a window that searched just stores and it worked ever so much better than the current design which males it harder to find what you want to buy.
There is no dropbox on the right for vendor. There are two: one for All/ Poser/ DAZ and another for sort order. That's all. One, two drop boxes. Before the redesign there was a dropbox for vendor but it has been gone for ages. The problem with the window on top is that even when you select Vendor it seems tp be searching the entire member list. So after entering two letters it seems to ignore anything you type next. So if it just searched the vendor list, there is one isn't there? I dare say it would work fine.
Here is the specific mater at hand. When an old product is gone from the store, I want to find out quickly if the vendor is gone too. Seems reasonable, right? Another case is when a vendor's name has changed. How to find the new name immediately, otherwise maybe the vendor is gone. Would be really helpful.
Thanks for answering.
Thread: Gallery Topic Areas | Forum: Community Center
Why not? I had thought of that. Probably the best bet. Thanks for suggestion. But still, Industry and Commerce should be there. It hs been a subject for art since the ancient Egyptians. You see it in tomb paintings.
Thread: Poser Has a New Base Figure!! | Forum: Poser - OFFICIAL
Having spent some time with the new figure I fine her a curious mixture of 'accuracy' and a body shape that would not past muster in an art school anatomy class. She certainly could not replace V4 who for all her flaws can be made to look like a real person. Enough different real people to populate a graphic novel. If that was not the purpose, so be it. But then I find it hard to see what everyone is so excited about. What kind of art is she actually good for? And by the way, accurate does not have to be average. Why not a base figure who is an anatomically accurate tall, slender female?
Thread: Easier way to fit conforming clothes to heavily morphed figure? | Forum: Poser - OFFICIAL
When you have bad poke through it is often because the figure is using morphs the wrong way. Look for negative morphs only a few are meant to be negative, breast size, nipple height, waist width, and hip size are the only ones that make sense when you think about it. So if you see thin at -.2 to make the figure bigger just set it to 0, etc. So you can avoid major grief by going to your V4 figure zero out the 'reverse action' negative morphs. If bad poke thru remains compare the figure morphs with the ones in the clothing and zero out the figure morphs that the clothing doesn't support. And if you reallly need them import them from the figure. Oh, and take the time to figure out how to use magnets. You can redesign the shape of clothing, bend skirts and do stuff that cause major pain with the morph brush.
Thread: Is it possible to parent a camera to a figure? | Forum: Poser - OFFICIAL
Here is what I do. Take A's face camera and zoom out and swivel around until you see the back of B's head then move forward a bit. Vice versa for B's face camera. I do this all the time for scenes with two characters so interaction is realistic.
Thread: Please tell me this isn't done | Forum: Community Center
In the marketplace I can't find the box to search by artist by name. Scrolling through the pages and pages of artists is HOPELESS. Do you really want to make it HARDER to shop, because that is what you have done. I finally found where gallery notifications are buried but it isn't the same as getting the signal of notifications and new site mail at the top of each page. Almost all text fonts are far too dark to be visible on a black background. Was bad before, now worse. Understand these need tuning - hope it doesn't take to long to return site to usability.
Thread: Pweermission denied | Forum: Community Center
