7 threads found!
meterman | 5 | 134 | ||
meterman | 4 | 101 | ||
meterman | 93 | 1061 | |
meterman | 17 | 493 | ||
meterman | 17 | 376 | ||
meterman | 8 | 366 | ||
meterman | 12 | 506 |
10 comments found!
Thread: Will Vue 6 infinite 32 bit run on a 64 bit OS? | Forum: Vue
Quote - Yes to Poser 7(it will install the x86 side) & V6I will auto detect the x64 OS & install as such(on the x64 side). Poser 7 is not a x64 app & V6I is (It comes in both x32 & x64 all in one)
I have no idea about LW.
The x86 side??? I'm sorry I'm a newbie kinda
Thread: Does Poser 7 run on 64bit systems better? | Forum: Poser - OFFICIAL
You all hijacked this thread from me!!! But in a good way this has been very informative now i'm left with three more components I have questions about the casing how many watts I should run for the power supply and the cooling system or fans?
Thread: will my XP/2000 version of Poser7 work on Vista? | Forum: Poser - OFFICIAL
also I have the Windows 2000/ XP version of Poser 7 do I need a patch of some sort to make it compatible with Vista ultimate 64 or is that even possible..if it is where would I get it?
So If I purchase Vista Ultimate 64bit Run a Intel Quad Q6600 processor, Geforce 8800 GT , 8 gigs of RAM, Video card 512mb what motherboard , and hard drives would you suggest? I was considering ordering from cyberpowerpc.com any other suggestions? Poser 7 Lightwave 9 and Vue 6 Inf are my target applications please be as specific as possible with suggestionsÂ
Thread: How do I allocate more Memory to Poser6? | Forum: Poser Technical
Thank you for giving me all these different avenues to approach I just recently upgraded from 1GB to 2 GB so i've done that I have a Pentuim 4 Chip I currently have a C + G harddrive space I've Defragged my comp a few times now And I too was able to listen to music run poser 5 , photoshop and surf the web but after awhile of using poser 6 these problems started I receive that message you are out of virtual memory you must allocate more memory to Poser , but now I'm receiving messages on numerous programs like internet explore having to close due to C++ Error can't open Firefox due to .exe issue etc. Someone bought up it could be a power supply issue how due I check that? Or anyother suggestions?Â
IF YOU CAN"T HELP!!! DO NOT DISCOURAGE THOSE HERE THAT ATLEAST TOOK TIME AWAY FROM TO TRY!!!!!!!!     Thanks all , The MeterMan
Thread: How do I allocate more memory to poser6? | Forum: Poser - OFFICIAL
So it wouldn't have anything to do with the General preferences setting render memory Memory limit buffer? I've been scanning the forums for answers....
Actually I was saving all along then as I added another prop or such I again saved then it happened . It rendered fine it just wouldn't save my file anymore once i received the message I could continue working until it was time stop for the night but nothing would save to the files file went to 0MB so I was unable import file too Vue.
