2 threads found!
mmandala | 3 | 71 | ||
mmandala | 5 | 151 |
8 comments found!
DalekSupreme posted at 3:13PM Tue, 31 March 2020 - #4384919
mmandala posted at 3:14PM Tue, 31 March 2020 - #4384898
If Mac users get a "malicious software" warning, here's the work around:
https://support.apple.com/en-gb/HT202491
Brilliant thank you!
Cheers!
Thread: Poser Pro 11.3 Released | Forum: Poser - OFFICIAL
SeanMartin posted at 3:11PM Tue, 31 March 2020 - #4384916
mmandala posted at 11:18PM Mon, 30 March 2020 - #4384899
I'm drawing a blank, but what's the method by which you re-link a runtime library? Installed the latest version (11.3 on a Mac) and I don't see any content libraries.
Open the Library window. At the top, you'll see a plus and a negative sign. Click the plus and direct it to the runtime you want to attach.
I thought that was it, but when I first installed the update, those features were disabled somehow. Had to delete and re-install to bring them back. Thanks!
Update:
I had to delete and re-install 11.3 (Mac OS 10.15.4) before it finally "saw" the content library in the UI. Weird, because the content library tab was there, but empty and without a way to add any runtimes--no +/- signs in the UI. I then had a way to add my DAZ3D runtime directory, but had to reboot in order to populate my previously saved scene with my DAZ figure (V4.2). Just a little stress - whew!
Thread: Broken Character Geometry | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
redphantom over at Renderosity figured out that it was a bend parameter turned off that somehow got tripped when visibility was turned off. Re-checking bend fixed the issue!
Thread: Walk Designer: Multiple Characters | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thank you, Boni! All good advice. I'm about to hit the Poser Manual to review animating walks, but off chance, can a walk path be made to go in the Y axis (up/down)?
