We couldn't find any threads matching the specified search criteria.
11 comments found!
Thread: Onslow--- Metering | Forum: Photography
histogram leaning real far to the left and those are the images I find are a bit to dark
There you go!...
Attached Link: http://www.dpreview.com/learn/?/key=histogram
You want to get serious about photography!! It shows you the highlights, midtones and shadows!!!! Your Canon DSLR should have that function on the LCD!Once you know how it reads....a breeze!!!
Different metering is employed for different types of scenes...hence why Cams have different metering anyway!...as is under/over Ev Comp!
Best way to see if a shot is 'exposed' the way you want it is to view the histogram!
Metering has no way to do with focusing!
Thread: Photo Walks | Forum: Photography
Fred, you will be amazed at how many photographers spend hours for that one special shot!...unless its a snapshot...not good for walking groups :-)
Thread: Excellent nature shots and macros. Take a look at this site. | Forum: Photography
Oh,my new name..!
You will find a lot of photographers use the EF500 with the 1x4....700mm@f5.6...cant be bad :-) I take mine on and off the 500 accordingly!
Also, a cheaper alternative is to buy the EF300 f4 prime and use the 1x4...420@f4!
which I also use, or just the 300 by itself!
Thread: New Genre - Photo Manipulation | Forum: Photography
