10 threads found!
morphometry | 3 | 80 | ||
morphometry | 4 | 87 | ||
morphometry | 5 | 112 | ||
morphometry | 3 | 761 | ||
morphometry | 10 | 179 | ||
Advisories: nudity
morphometry | 30 | 857 | |
morphometry | 3 | 1351 | ||
morphometry | 6 | 126 | ||
morphometry | 3 | 79 | ||
morphometry | 4 | 124 |
28 comments found!
The InDesign Column needs a picture; that picture only needed to be copy the Introduction column ,over again; but this is becasue nobody had a great idea for how to represent what was/was_being layed out with InDesign. This is perfect.
Still hoping for something to replace my Scrolls idea; for the text panels though?
Thread: Restaurant Menu Prop? | Forum: Freestuff
Thanks!
It would'nt need to be tri-fold prop, that is just what I'll actually need to have printed for class(See bottom two pics.) A bi-fold is'nt necessary either. Just a rectangle board with triangle shaped(Metalic) clips (fancy) at it's corners to hold a paper to the board(the actual menu page.)
If it were bi-fold, and with the clips I mentioned(what are those called...) I could render it out and then split/mirror one of the pages in Photoshop.
Thanks Again!
Community Center; I posted this to the Poser forum?
Thread: Honda CBR1100 and other surprises | Forum: Vue
I've scaled down the UV Scale, of this very simple Polka Dot, several times; but each time I get this same render?
Has anyone found, or managed to succeed at, a UV Map; for this model?
I've tried exporting .OBJs, from Carrara and Poser; but UV Mapper then shows no vertexs, nor lines? I've tried going ahead and exporting the Texture map, anyhow, but Photoshop shows an all white document?
MO~
Thread: Rotating a Material 90 Degrees? | Forum: Poser - OFFICIAL
I was hoping we could insert some node to connect to the MatmaticSurface Diffuse_Color?
Attached is the material file. Just rename it to WoodButcherBlock.mt5 when you download it.
Thread: Can .PSDs be Merged? | Forum: Photoshop
Thread: Buildingtop Billboard Prop? | Forum: Poser - OFFICIAL
Dystopia City Blocks rule!
The Free Dystopia Sky Dome, at Daz3D, is the skydome I'm using in this scene; where do you see a billboard, can I get a link?
Hiya Ockham!,
We're 2 months into the semeter! I've a B- ri(...I forgot some stuff...but there is extra credit due...)ding, on this next assignment.
Professor Beaudoin agrees that my "CAFE" logo(the text) is not highly visible int this image; hence my attempt to add this billboard prop...
} = ) 8 -
Thanks!
I certainly won't starve, for lack of resources!
Ockham - I especially like the ribs(...?) on the side of your billboard. I had'nt hoped to see that anywhere, but it certainly gives a very nice feel; kinda like a movie premiere from the..1920's? Very nice!
Wheatpenny - Yours is very realistic! It's study construction is definately a plus to this object; It would look right at home in several key locations, ie.e on top of a huge skyscraper, or beside a wide and flat superhighway area. I'm just not sure I would'nt have the same problem I had with my second post, over again. I'm going to go try to load this prop, and see if I can't turn the visibility for some of the supports off!
The freebie was probably rendered in Poser 3/4. It's a little old, and so was the building under it. I've been really hoping to find it, because it would just look natural in this picture.
Thread: SVDL Dynamic Free Stuff | Forum: Poser - OFFICIAL
I Pinned it; but I'm not sure of my workflow, from the get go?
Pluto, Jan - Thank you both; this is exactly what I hoped to do!
I just wish I really understood the principle behind what's going on. WHen I use the Group Editor, to select what's getting pinned, what am I pinning that cloth to?
Here we are at Frame 5 of my Simulation. This looks like a nice place to reference where I'd like the cloth slip over her shoulder to. So, at frame 5, I began my Constraint Group; and then just added the a bit of each side of the collar. Then I set a Key Frame, went back to Frame 1, and...
Thread: Menu Prop? | Forum: Poser - OFFICIAL
