9 threads found!
p3t2 | 6 | 279 | ||
p3t2 | 42 | 826 | ||
p3t2 | 4 | 99 | ||
p3t2 | 14 | 220 | ||
p3t2 | 5 | 139 | ||
p3t2 | 11 | 110 | ||
p3t2 | 8 | 138 | ||
p3t2 | 8 | 248 | ||
p3t2 | 9 | 159 |
40 comments found!
Thread: what makes these renders so different? | Forum: Poser - OFFICIAL
it seems to me that Poser just refuses to load the _bmp and _dis images, no matter what I do in the Material room. the two mini windows relate to bump under both "Simple" and "Advanced" tags are simply blank, whether or no I manually direct the image source to the targeted image files.
clearly, there must be something wrong. here are some key problems I have.
1)everytime after applying textures from Poser Pose folder and render for the first time, Poser will pop up a window, saying that "texture could not be loaded. Image map file could not be found."
2)under the same situation, the same message will also pop up if trying to go into Poser Material Room, rather than trying to render.
4)tried disabling all "smooth polygons" functions from both Properties and Render settings, but nothing changes.
5)tried activating or disabling Use Displacement Maps in Render settings and setting Min Displacement bonus, nothign changes, escept that with Use Displacement Maps On, the LOWER part of the helm distorts, as shown by the image attached.
desperately need helps!!!
could some Poser experts take a close look at them please?
maybe you can help me figure out what has been going wrong.
thx.
here I attached some screenshots of my Poser features before rendering.
and also you can see another problem with the helm: everytime I checked the Use Displacement Maps box, the Face Plate of the helm distorted.
really confused.
some more helps please?
thx.
Thread: who recognizes this model? | Forum: Poser - OFFICIAL
