32 threads found!
pacanne | 1 | 122 | ||
pacanne | 6 | 135 | ||
Advisories: nudity
pacanne | 29 | 413 | |
pacanne | 20 | 456 | ||
pacanne | 13 | 428 | ||
pacanne | 6 | 137 | ||
pacanne | 19 | 263 | ||
pacanne | 10 | 203 | ||
pacanne | 15 | 400 | ||
pacanne | 28 | 448 | ||
Advisories: nudity
pacanne | 30 | 787 | |
pacanne | 1 | 100 | ||
pacanne | 6 | 270 | ||
pacanne | 4 | 118 | ||
pacanne | 4 | 106 |
132 comments found!
Thanks, guys, I'll try your recommendations. Most of these issues are arising with some of the older Kozaburo (sp?) hairs and P6 and P7 ones....I was going back to some older work I had done.
Thread: Hair position changing with pose | Forum: Poser - OFFICIAL
Hi Vilters,
Actually the hair in question is one of the original Poser 6 Jesse hairs, and it seems to be parented to Vic when it is loaded. What I can't figure out is that it remains attached and bends with the figure for the vast majority of poses, but with certain ones the positioning gets reset to the default 00. Usually I have to adjust the position of the hair for the x,y, and z. For these poses, for some reason, the positioning is returned to zero.Â
Thread: Contrast issues with renders | Forum: Poser - OFFICIAL
Hmm , I might have to look over the posts again. Where can I find bagginsbills shaders? Thanks!
Yes, I am just puzzled because the skin is made by a reputed renderosity designer--it's the Demi skin http://www.renderosity.com/mod/bcs/vh-demi-for-victoria-4-2/87839
I would imagine this guy would have done a professional job. The figure is beautiful but I am wondering if I am doing something wrong on my end....I wouldn't expect that he would be incompetent enough that all the folks who buy the product have to make such delicate material room mods.
Would love your opinion on this. Perhaps one or several of you have this figure and skin.
Thanks for your patience. You're right I am just getting familiar with the material room, and haven't tinkered with nodes at all. I will follow your suggestions and consult the manual.
Just to clarify things, what I am doing is basically modifying the specific skin of this figure? Once I make the changes I can change lights and the changes will improve the end result... When I say "skin", I am of course referring to the shaders embedded in the skin, if that is the correct terminology.
I see a blue and violet "string" coming out of Color Ramp, trying to see what they're plugged into. How do I turn them to black?
Now, I am a neophyte at all this, but this skin is an AO (I assume that is the shader?). I tried the same skin without AO and there was no difference.
Well I have P7 which seems to be one of the older generation of shader simulators. When did they begin using SSS lighting, etc? With P8?
Â
Thread: seams in skins | Forum: Poser - OFFICIAL
Yes, it seems the effect is lessened when you go to max settings...but not totally eliminated. I ran raven's script, but didn't see any difference. I selected the figure in question in the material room, and then selected "quality". Is this the right approach? Thanks guys for all your patience:)
TY for all the tips. I am not an expert user so I'll see where I can find those shade settings in the material room. TY Raven for the link, I'll take a look :) I am just curious why that phenomenon happens with certain skins...
