We couldn't find any threads matching the specified search criteria.
5 comments found!
Thread: whats the best vue for home if i have xStream in the office? | Forum: Vue
Hi Chris,
It all depends on how extensive you would like to get into the program. To me, Vue 7 Infinite is the best for your money, but if you are just a hobbyist, Vue 7 Complete is the way to go. It allows you basically the same accesss to the features in Infinite, but not quite 100% and the end result is just as nice. But if you are serious and use the program often, then Vue 7 Infinite is the way to go. You would have to try all the versions in order to come up with the correct one for you. So I suggest you do that before you just go out and purchase it.
Hope this helps!
Rich
Thread: Shadow Catching | Forum: Vue
Yes, I would like to see what you are talking about. For that matter, anything that would better my skills at using Vue 7. Thanks so much!
Thread: anyone explain about the environmental lighting regarding vue and industrial? | Forum: Vue
Hi,
At this point because it would take too long to explain... do a search in your browser for Vue environmental lighting tutorial. Or visit e-on and have a look at their tutorials. I'm sure they'd have something you need. Other than that, it's pretty much trial and error and that takes a while which it sounds like, you don't have.
I hope this helps!
Thread: Unable to create a water plane | Forum: Vue
Quote - After working on a scene for a while, I saved and then exited Vue 7 Complete (latest update). I then opened Vue up again, reloaded the scene and tried to add a water plane. Each time I attempt to add a water plane, it just increases the altitude of the ground plane without adding anything. Anyone else had this one come up? I tried it with a new test scene and everything worked as it should, its just with the one scene. The scene works fine apart from this, so I don't think it is corrupted.
Hi,
I've experienced similar problems in Vue 7 Infinite and there are several bugs in their new versions. I was reassured that some time in the future, they will have an update that will fix all ot these. Until then, we're left fighting with this software in order to try and get it to work properly which in my mind, is not right! Sometimes when I insert a new terrain, it completely strips the other mountains of their eco systems. Oh well, we're stuck with it until e-on fixes the problem.
Rich
