1 threads found!
procrustes | 20 | 694 |
24 comments found!
Quote - Need help please!
Im pretty much beginner working with Poser and im trying to transfer morphs from Victoria3 to Victoria4. Therefore I run TDMT_Match6b.py and get quite a good correlation with distance cutoff 0,005 and ray-casting. Than I use the newly created .vmf and run TDMT_match_transfer1g but it always says "Morph Creation Failed" and Im not able to transfer anything. I tried it many times with different morphs and .vmf files but nothing worked.
Anyone got an idea what the problem is??
The morphs you want to transfer should have a value other than zero - just dial them up
Thread: The LuxPose Project - Alpha Stage | Forum: Poser - OFFICIAL
I am not sure if this will give the same results but I try - but I stop now, because I dont want to hijack this thread with something else
The skin texture I used is Hanyma -from AerySoul - its very light and just plain plugged in. Probably skin textures should have realistic skin colors and should not be trimmed for other renders. Another thing that puzzles me in those renders is that most of them are too dark. Probably nobody uses the controls in LUX and sees the possibilities there.
You name the lights in Poser for instance to "G1: light" , "G2:light" etc and you can have more than one light in a group. The IBL picture has to be an "filename.exr", but Photoshop allows you to save hdr files as exr.
You can make the changes even during rendering in LUX - this is really fun. I am moving on to car rendering now. Here I just wanted to see if its possible to render a more complex scene. What I learned was that the more bright and non white colors you have - the faster the rendering is. You can also find such hints in the LUX documentation which is really useful.
What I also want to try now is creating HDRIs, it should be possible, because you can render at different Fstops with a given value of ISO.
Thanx to all the people who have put their efforts into this. I wondered what LUX actually does or can do - because when I look at pictures with the reality sticker on it on the other side, they actually don't convince me at all, most of them are as badly rendered as in 3Delight.
Thread: Car paint - a challenge | Forum: Poser - OFFICIAL
Thread: 3D stereoscopic in poser | Forum: Poser - OFFICIAL
Try this software - is java and has everything you need - inclusive the tutorials:
http://anabuilder.free.fr/welcomeEN.html
Thread: You cant render cars anymore in P8 | Forum: Poser - OFFICIAL
Thread: Morph Cleanup Script | Forum: Poser - OFFICIAL
