4 threads found!
puzzledpaul | 0 | 5 |
(none)
puzzledpaul | 2 | 7 | ||
puzzledpaul | 4 | 28 | ||
puzzledpaul | 4 | 562 |
40 comments found!
Attached Link: http://p212.ezboard.com/fnendowingsmiraifrm17.showMessage?topicID=1740.topic
np - hope it helps :) (attached also shows you don't need to spend any money on s/w to get a decent result ...) pp http://www.military.com/soldiertech/0,14632,Soldiertech_G11,,00.htmlThread: Looking for Blueprints | Forum: 3D Modeling
Attached Link: http://www.subdivisionmodeling.com/forums/showthread.php?t=7
Also just noticed post #4 in this thread :) ppThread: Looking for Blueprints | Forum: 3D Modeling
Attached Link: http://www.military-meshes.com/forums/
Maybe worth checking the refs section of this site? ppThread: OT- I need a translation from french to english | Forum: Photography
Thread: Scavenger Hunt #20 Capture someone ELSE taking a picture | Forum: Photography
Hope this isn't considered pic overload - but had these lying around after a trip to London in Easter this yr. Most of the above were trying to get a pic of Big Ben / Houses of Parliament. No cropping, Canon D30 / (old)100-300 5.6L pp
Thread: Help finding car blueprints? | Forum: 3D Modeling
Attached Link: http://www.nfscars.net/forum/archive/index.php/t-2914.html
sm is supposed to be goodThread: selling my Carrara 1.1 | Forum: 3D Modeling
Might it be worth noting that this app is an uncrippled freebie on the current issue of Digit mag? (There's also a deal for UK / European readers to upgrade to 2.0 for 99) pp
Thread: Amateur modeling and Blender 3d | Forum: 3D Modeling
<< ....and regarding wings, I tried it but didn't like the controls very much .....You don't need to click on any buttons because just about everything can be done with the keyboard.... >> The vast majority of tools (within Wings) can be assigned to hotkeys of the users' choice - the same hotkey can be used for the same command across all 4 selection modes (verts/edges/faces/objects) eg - it's then possible to have 5 keys for all (19) of the major move commands - and therefore not have to touch the menus :) (I also have a similar setup covering scale/extrude/extr region/rotate etc) Anyway, good luck - whatever you use :) pp
Thread: help for a totally newbie | Forum: 3D Modeling
Attached Link: http://www.geocities.com/paulthepuzzles/aardvarks.html
You might also be interested in trying out the BT1 tut at the linked site - there's other wings specific info at the same site as well :) ppThread: New version of Wings out! | Forum: 3D Modeling
<< Still, it's nice to have both >> Yep, no argument:) It's always great to see a (real world) product that's 'just right' -imo. Elegant design, well made, works well, easy to use / maintain etc (not too many around these days) I suppose this is what we'd all like re wings - and I wouldn't argue - especially re user prefs for customising UI etc, because there's no way one UI will please everybody all the time :) I only made the comments I did because of the situation here - ie limited time /resources,(although it often doesn't seem that way!) and in this context I'd always like to see better / improved tools etc - rather than the reverse. There's also an interesting discussion re whether 'looking more professional/commercial - like the 'rest'' is good or bad? Job for the pub one night when it's catting 'n dogging? :) pp
<< I can't find the transparent option, where is it? >> Edit -> UI prefs -> Menu Bkgnd (say) -> A (Alpha) slider (adjust this) << then i like to just see my model so im wierd >> Well, there's at least 2 members of the 'weird club' :) Whilst it's great to be able to work in a 'comfortable' environment (check out 0.80 to see how much has improved) - it's surely the quality of what's being made (and the tools available) that's most important? Does painting the handle of your favourite carving chisel make you a better carver - or how you use it and how well the cutting edge is honed? Ask yourself the 'Bay' question - with the current Wings toolset, would he be able to make his usual quality of model? - or would he need a 'prettier / more pro 'looking' UI to do this? I suspect we all know the answer :) pp
Attached Link: http://pub33.ezboard.com/fnendowingsmiraifrm1.showMessage?topicID=1465.topic
Tweak - there's already a 'patch' available, which fixes the problem :) ppThread: modeller.....? | Forum: 3D Modeling
Previous (fully working) releases of Pixels3D are regularly put on the cover cds of mags in the uk (Digit/Macworld etc) - dunno what the latest freebie version is - maybe it'll say on their site? I've used a very old version on an ancient 7500/100 Pmac - very slow, but some interesting tools - the files also seemed to export fine into other things I was using at the time. Well worth investigating imo. I now use Wings (on a pc) and also suggest you should try this - totally different way of working to P3D - but excellent (imo) for modelling many types of objects - and very easy to pick up the workflow. pp
Thread: is your modeling camera set to the correct degree ? | Forum: 3D Modeling
I once posted some viewing angle figures for 35mm camera lenses (on the Wings forum) - but can't find them :) A 50mm 'standard' lens (one that used to come with the (SLR) camera - in previous days) has a (diagonal) viewing angle of 46 deg. This was supposed to give a view similar to that perceived by the eye. More recently, a 35mm lens has become more 'popular' - view angle for this is 63 deg. (Typical focal lengths for taking 'portraits' are 85mm - 100mm - with corresponding view angles of 28.5 and 24 deg respectively) Depending on what's being modelled, it might be worth messing around a bit? :) (Lens details from Canon EF series, btw) pp
Thread: Model price? | Forum: 3D Modeling
Attached Link: http://www.suurland.com/gallery_stills_newbeetle.htm
Makes me wonder how much this guy charges :) ppThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
