59 threads found!
quesswho | 1 | 132 | ||
quesswho | 2 | 244 | ||
quesswho | 6 | 261 | ||
quesswho | 17 | 501 | ||
quesswho | 1 | 35 | ||
quesswho | 0 | 25 |
(none)
quesswho | 4 | 41 | ||
quesswho | 4 | 94 | ||
quesswho | 14 | 148 | ||
Advisories: nudity
quesswho | 0 | 17 |
(none)
quesswho | 1 | 17 | ||
quesswho | 12 | 89 |
2000 Aug 10 10:13 AM
quesswho | 2 | 40 | ||
quesswho | 4 | 56 | ||
quesswho | 2 | 31 |
2000 Aug 02 5:37 PM
426 comments found!
thanks Pinky, I have gone to all the sites and redownloaded my purchases, which is great considering how long I was away and my email changed. Those are the last two, lol
Thread: Help making a water ripple | Forum: Vue
Attached you will see what I did
I want to tahnk all of for all your help. I made a terrain and added a water texture to it. Attached you will see what I did
Thread: Libraries | Forum: DAZ|Studio
What I did was create a new folder in my runtime/libraries/Pose folder called Poses. I placed copies of all my pose files minus the #switch banks#file(I have PBOOst) into this folder and had DazStudio find it under other daz content. It works just fine. I did find adding the content difficult at first but when I realized that all you had to do was browse to the Poser 4 folder and not to runtime as I thought things worked perfectly. Marge
Thread: cyclorama | Forum: DAZ|Studio
I did move them out of the scene is was working on but I lost a little of the depth that I like so much in cyclorama, so I am working on figuring this out. It is nice to know I am not the only one. I get some pretty funky comp. probs sometimes. For the most part I am liking DS the interface is good and once you get used to manipulating models it works very smoothly. I seem to be missing a large section of the PDF though. Anyone else? Marge
Thread: PBoost Start | Forum: Poser - OFFICIAL
CorrectReference fixs incorrect references in your Poser files. A free utility, CorrectReference scans through your Poser library folders fixing incorrect image references within the files. http://www.horseless-headsmen.co.uk is where you go to download it Marge
Tell me about it! Just so ou know there are times when PBooost gets finiky, that happens when the path needs correction go to his website and download the free program "correctReference" and run your runtime directory through it. Good luck I have found the program is very convienient. Marge
Well first you open it, then you decide which of the Library banks you want to use(personally I have only used the poses one) then you click add at the bottom left and name your categories what ever you want( Michael, Michael 3, Freak etc) the by using the right click you drop and drag from the right side to the left side (where you have your newly named categories. I hope that helps, if you want to use PBooost all you do is have the default poses( or whatever library you use) set to what ever su-category you want, start Poser and then going into the poses Library click "switch Banks" when ever you want to change banks(don't forget to switch banks in PBooost also). Marge
Thread: I'm confused!!!! daz PC renewal !!!!!!!!!!!!!! | Forum: Poser - OFFICIAL
I had this problem. My membership expired on the 15th of October and I had it all set for automatic renewal. It even said automatic renewal next to Platinum club membership.I called Daz to find out what had happened. Well it doesn't automatically renew, it turns out automatic renewal doesn't work with the yearly membership only the monthly. The took my basic information over the phone but had looked my up on their computer and got my cc info that way. Very quick and very painless. Of course the wording should be clearer but the do go out of their way to satisfy. Marge
Thread: Great Automobile Hearse Photos Here! | Forum: Poser - OFFICIAL
We actually own one. It is a '49 Pontiac. Runs beautifly, though the interior needs work. Marge
Thread: when did DAZ say the 1st M3 upgrade would come | Forum: Poser - OFFICIAL
Thread: Daz Millenium Dog | Forum: Poser - OFFICIAL
Thread: Ok so why does firefly hang? | Forum: Poser - OFFICIAL
I have an ASUS 7V333 and have only had the hang problem after many renders or when I use. I have the most certain light sets. When I first used P5 I had problems with a certain background and prop(one of the Transpond ones) but since I started updating my bios I really seem to have solved my problem for the most part. I still turn off P5 after several renders you can tell when it's getting tired, and I save all the time just in case. Marge
Thread: anyone know these poser models | Forum: Poser - OFFICIAL
