Sun, Feb 9, 5:09 PM CST
Subject: PBoost Start
arrow1 ( ) posted Sat, 22 November 2003 at 5:20 PM · edited Sun, 09 February 2025 at 5:07 PM
I have had Pboost for sometime now and I don't seem to understand how to get started with it.I have tried to read the instructions but to me they are all over the place.Can anyone help with a simple A B C of how to get going on this product that everyone seems to be using? I have downloaded the latest update! arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
quesswho ( ) posted Sun, 23 November 2003 at 5:35 PM
Well first you open it, then you decide which of the Library banks you want to use(personally I have only used the poses one) then you click add at the bottom left and name your categories what ever you want( Michael, Michael 3, Freak etc) the by using the right click you drop and drag from the right side to the left side (where you have your newly named categories. I hope that helps, if you want to use PBooost all you do is have the default poses( or whatever library you use) set to what ever su-category you want, start Poser and then going into the poses Library click "switch Banks" when ever you want to change banks(don't forget to switch banks in PBooost also). Marge
arrow1 ( ) posted Mon, 24 November 2003 at 12:32 AM
Many thanks for your reply.I will give your suggestion a try! Like you I only want to use it for poses as my pose file has 399 files.arrow1
quesswho ( ) posted Mon, 24 November 2003 at 10:10 AM
Tell me about it! Just so ou know there are times when PBooost gets finiky, that happens when the path needs correction go to his website and download the free program "correctReference" and run your runtime directory through it. Good luck I have found the program is very convienient. Marge
arrow1 ( ) posted Mon, 24 November 2003 at 2:55 PM
The Poser community is fantastic! in just two posts I have a program working that I have had for some time and could not understand the instructions.Just one other question without confusing me! What is correct reference? and what does it do? arrow1
quesswho ( ) posted Mon, 24 November 2003 at 3:15 PM
CorrectReference fixs incorrect references in your Poser files. A free utility, CorrectReference scans through your Poser library folders fixing incorrect image references within the files. http://www.horseless-headsmen.co.uk is where you go to download it Marge
arrow1 ( ) posted Tue, 25 November 2003 at 12:55 AM
Many thanks once again! arrow1
