1 threads found!
relaxis | 7 | 126 |
7 comments found!
I realised that when i sculpted the clothes in zbrush i sculpted them from a non-zeroed export of ryan. Whoops. Back to the drawing board!
Thread: Need help with poser setup for conforming clothing | Forum: Poser - OFFICIAL
Hey,Â
managed to get your steps to work, the problem is that now I get tears like this - how do I fix this? - img -Â http://www.picfront.org/d/8DIY
Â
Hi Philc,
Â
thanks - followed all your steps - stupid question - save figure - is that as in "file">save/save as ?
Â
Thread: Ideal Poser render node, hardware mavens please hit me. | Forum: Poser - OFFICIAL
where can I get a copy of that? I'm personally having a hard time rendering with Vue right now. Rendercow crashes on the first frame every single time and I lost my registration code so I can't download the update to fix it. Anyone have a perfectly decent (working) copy of rendercow?
if you're setting up a render farm then you just need the bare minimum and a good cpu. although cpu (to a certain point) speed hardly affects rendering speed within renderfarms, you also don't want to bottle neck your multitasking abilities on each pc. personally i would buy lots of cheap pcs and rig em together, sod the specs.
basically you want a 64mb graphics card. you can buy them for as little as 10 euros to 100 euros. But you will need a lot more than 64mb graphic card if you're going to be using 3d stuff. Hell, maya 7 doesn't even run unless you have 128mb graphics card and even then it slloooowwwww
I knocked this set up together for 1500 euros and it works perfectly for me - amd x2 dualcore processor 3800 2 gigabytes ram 200 gb hard disk GIGABYTE nvidia geFORCE 6800 GS graphics card. nvidia motherboard with 4 slot SLI ice pipes then overlock the bugger to 60 degrees Celsius. Best thing about the graphics card that I have is that the 6800 gs works amazingly in tandem.
