8 threads found!
romanichel | 0 | 60 |
(none)
romanichel | 1 | 52 | ||
romanichel | 1 | 91 | ||
romanichel | 13 | 197 | ||
romanichel | 0 | 17 |
(none)
romanichel | 2 | 87 | ||
romanichel | 4 | 121 | ||
romanichel | 6 | 209 |
8 comments found!
I have no more precis questions for the moment! I just want to try to make some morphs target, and also create clothes with max, in the future. For the moment, I am just in the beginning of learn.
Thread: need help for create morph target with 3dsMax | Forum: Poser - OFFICIAL
Thanks Magnus! I tried again, and that works well! Anyway, if you know some tips for make morph targete withs 3dsmax,that shall be welcome. Thanks to alls!
Thanks Magnus. I just tried the settings you wrote, and it is much progress. The object only move up a little. I must try again!
I tried with and without the morph target checked when export object from Poser, but I have always the same problem. it is some import and export settings in 3dsmax,and I tried some also!
thanks for yours answer, but the problem for now, is for the import/export setting. without any change, only import and export,the object seems to move.....
Thread: morph manager | Forum: Poser - OFFICIAL
Thank you for your help. It seems, I must copy body channel in first, and then the body part morphs.
I copy all the morphs of all the body parts, and all the channel of body. The dial controls of the body part are effectives, but not the dial body! Must I make another things?
I copy well the body channels, but if they appear in the parameter dial in Poser, they don't are effective. They are not effect!:-(
