2 threads found!
russ555 | 2 | 73 | ||
russ555 | 7 | 113 |
8 comments found!
I just enabled it in the render settings xD
I will go read now and thanks for the link wiz.
Thread: Need advice about Poser 9 | Forum: Poser - OFFICIAL
I just loaded V4 applied a texture, enabled SSS and rendered.
I didn't have IDL enabled which would explain why it didin't work. I just tried it again with IDL enabled and the only difference I could see was much longer render times and a brighter image at the end.
Does Sub-Surface Scattering require special textures or something? I tried it yesterday and my render looked exactly the same :S
Thread: Disabling Keyframes | Forum: Poser - OFFICIAL
Thread: Inserting an item into a specific set of frames. | Forum: Poser - OFFICIAL
Got a similar issue with parenting objects now.
I want the object parented with nothing until the hand gets in place to pick it up at which point I want it to become parented to the hand. Is this possible?
Quote - You can also just move them out of the camera frame. If you keyframe the start and end frames for the motion Poser will do the rest.
I tried something like that. Not sure if it was using key frames though cos I don't really get how to use them.
But I selected say frame 10 loaded the bubbles, selected frame 30 and moved them up and off camera. The problem was that from 1-10 they would be sat there looking silly. If I tried starting them off camera in frame 1 and placing them in the right place between frame 1 and 10 you would see bubbles float in from the side lol.
The first method works fine though and is nice and easy so it doesn't matter now.
Thanks to both of you.
That worked great, thanks a lot.
I feel like an idiot now. I spent hours trying to figure it out lol.
