4 threads found!
studio187 | 3 | 162 | ||
studio187 | 4 | 211 | ||
studio187 | 1 | 12 | ||
studio187 | 5 | 36 |
7 comments found!
Thread: Articulated Helmet | Forum: Poser - OFFICIAL
I can do that already. I was hopeing you could fill me in on how to attach an OBJ to it for texturing purposes. Additionaly, when you add it to the library will you be adding it as a character? I don't think you can make a prop with two pieces from the Poser interface.
Thread: Tolkien WIP (again) | Forum: Poser - OFFICIAL
I'm not sure but I think the PZ3 to CR2 program will meld the clothes (and props and everything else) with the figure.
Thread: How exactly, do the Geometries Objects interact with the CR2? | Forum: Poser Technical
Let me try this again. If I build a custom figure from an existing one how do I get the CR2 to use the new OBJ? Here's what I did. I took the existing P4 female nude as my starting point. I made some spider arms in AutoCADD and exported them into 3DS. I then imported the pieces into Poser4. I attached them, parented the leg pieces together and saved one leg as a character. Then I pulled in four of them and attached them to the Female. Parented the legs to her chest and pow I now have Spider Women. Here's the problem. I now want to put 1 OBJ in the Geometries folder so I can have one texture for her and her legs. I can export her as an OBJ and I put that OBJ into the Geometries folder but I can't get the CR2 to recognize it properly. I don't know how they work together. I don't know what the CR2 needs to know about the OBJ
Thanks Jeff but perhaps I didn't say it right. All this I already know. How do I make the CR2 in the LibrariesCharacter section reference the OBJ in the Geometries section. I don't have an OBJ with the girl, and the arms. I only have a CR2 in the LibrariesCharacter section. This is what I did. I made the spider arm in autocadd. I then exported the pieces into 3DS (Cadd does not do OBJ format). I pulled the pieces into Poser and attached them, adjusted the joint perameters and parented them to the standard nude P4 woman figure. This gave me a PZ3 file. I then used the new PZ3 to CR2 program to make a CR2. It works great. Here's the problem, I want to make textures for it (as one who figure) and don't know what my next step is. I want to have the woman with the arms as one figure not as several different parts. Thanx.
Thread: Poser4 STILL can't multi-task.. this was a prob in Poser3 too | Forum: Poser Technical
I have two monitors and it works fine. Could be the card your useing. I'm using a $1200 card, that might be the difference.
Thread: FemaSu CrossDresser 3.0 issue | Forum: Poser - OFFICIAL
