3 threads found!
taiuri | 2 | 214 | ||
taiuri | 27 | 824 | ||
taiuri | 16 | 651 |
36 comments found!
willdial posted at 6:55PM Tue, 25 June 2019 - #4354592
Here is a link to a webinar that covers Genesis 3 in Poser 11: https://www.youtube.com/watch?v=mEfMP7aQ-NE
Thank you for the link. I understand it's the same procedure for Genesis 8, don't I?
Thread: Genesis 8 in Poser 11 | Forum: Poser - OFFICIAL
Could you make a video tutorial in Youtube about how to install Genesis 3 and 8 in Poser 11 please?
Thread: Can't find Kinect Capture in Poser Pro 11 | Forum: Poser - OFFICIAL
Elnasr posted at 7:20PM Tue, 15 January 2019 - #4343685
taiuri posted at 7:06PM Tue, 15 January 2019 - #4343590
Elnasr posted at 7:20PM Sun, 13 January 2019 - #4342791
Sorry for those that couldnt connect..open python kinect path and modify the script , change IsPoserGameDev to poser and save and restart now it shows
Which one is the one I must modify? I have: ini.py, Bridge.py, Bridge2.py, filter.py, KCBv2.dll, KCBv2_32.dll, KinectCommonBridge.dll, Main.py, Quaternion.py, scale.py
Could you explain us please?
init Where it shows " isGameDev" change it to "poser"
Oh yes! It worked!! Thank you so much!!
Thread: Request of an Cr2 Exporter Updater for G3/8 Figures/Clothes | Forum: DAZ|Studio
RHaseltine posted at 12:59PM Tue, 19 June 2018 - #4332059
Poser doesn't currently support the binding method used by Genesis 3 and 8 (Dual Quaternion) so there would be no point in an updated exporter, I fear.
At least it's possible Genesis 3 Figures/Clothes. Just 2 years ago me and another person were able to do it, but nowadays Daz made something in order to the exporter can't export a lot of data. That's why I'm requesting a Cr2 Exporter Updater. I hope someone can create it.
Thread: Problem importing G3M Clothes in Poser 2014/11 | Forum: Poser - OFFICIAL
A friend told me the problem the clothes get distorted is a bone binding problem and it's necessary to synchronize pants and body bones, but I don't know how to do it Poser. Do you know something about how to do it? Could you explain me guys, please?
If I create a DSON for the Figure and the Clothes, it worked, but I prefer the Cr2 Exporter method. I don't like to import them through DSON. Could someone here try to export a Genesis 3 Figure to Poser by the Cr2 Exporter Method please? I need to know if the problem is general or only mine.
infinity10 posted at 3:40PM Thu, 31 May 2018 - #4330894
jeffnlkpt2 posted at 11:47AM Thu, 31 May 2018 - #4330875
What I do is do an autofit in DAZ and then save the object as a figure asset. I then create a poser companion file with DSON. I have converted a lot of clothes this way and has never had an issue.
Theoretically, this seems the correct methodology. Also, I suspect one issue with all solutions not working is to start with a new scene. poser memory gets very bad when the same scene is used to re-import Daz Studio content either via ObJ and CR2 or by DSON.
Could you try by yourself in your pc and let me know if you have this issue too. I have to know if the problem is general or only mine.
This really strange, if I export directly the G3M Figure and his cloth to Poser, it's not exported complete:
Could you do a favor? If you have Daz Studio, Poser and Genesis 3 Figures and some G3 Clothes, could try to export it to Poser following the method I explained before and tell me your results please? Problably it must be a Plugin or something like that I need for Poser.
I'll be waiting your results. Thank you guys.
RedPhantom posted at 7:02PM Wed, 30 May 2018 - #4330891
you might try adjusting the weight maps or inner matspheres (depending on how the figure is rigged) with the joint editor window.
I tried and neither i worked :( There is something that Daz is not exporting to Poser, but what? what could it be?
