6 threads found!
theWul | 3 | 104 | ||
theWul | 10 | 169 | ||
theWul | 4 | 189 | ||
theWul | 7 | 315 | ||
theWul | 26 | 669 | ||
theWul | 2 | 203 |
20 comments found!
Thread: Help on Textures not loading properly please... | Forum: Poser - OFFICIAL
Hehe, ok, once more... It's P5 SR 4.1. It's Vicky ... ... with different custom textures saved as different characters. When those characters are loaded in Pose Room in texture shade mode some of the materials simply show up white. Renders are correct. After switching to Material room and clicking a white material it's texture shows up corretly... Hmmmmmmmm... Me thinks I applied those textures via P5 Materials, but I'm not sure... Strange, hu?
thanks for your efforts so far =) and ... ... yes, the rest is white. ... yes, textures are applied. ... yes, SR 4.1 ... Low Memory? happens on my 1024mb as well as on my 512mb Windows XP. ... clean started poser, one figure won't work, others do... sigh
Thread: Is Poser slowly dying? | Forum: Poser - OFFICIAL
depends on how poser will develope... I think in one or two years there will be poser-like software with working dynamic hair and truly "conforming" clothing... add plugins to export to common games (like Quake or Sims 2) and you have a winner... Poser with its lack of support from CL will be dead meat as soon as any new picks up the challenge...
Thread: Modeling clothes for Poser...? | Forum: Poser - OFFICIAL
3Ds Max? nobody mentioning 3DS Max with the .OBJ-Plugins? ... works fine to me after some ... err ... getting used to it =)
Thread: Can IK be turned off with a POSE? If so, how? | Forum: Poser - OFFICIAL
AFAIK Poser automatically sets the IKChain for leftLeg and rightLeg to "on" whenever a figure is loaded, and you have to RENAME the IK chains (for me calling 'em "left_Leg" and "right_Leg" did the trick)...
Thread: Magnets and Morphs behave different? | Forum: Poser - OFFICIAL
I did some further exploration in this and found out that the magnet and morph-from-magnet only behave different when the magnet is rotated (in the picture the magnet's x-rot was set to -61)... So this finally seems to be a bug. Where do I send this?
Thanks for your efforts so far, but: as you can see the dial for the magnets influence on the right buttock is set to 0 while the morph dial is set to 1. Switch those settings (magnets influence to 1, morph to 0)and both sides look similar (because the magnets base and zone are in the middle of the X-axis)...
Thread: It's amazing what you can do with a Digital Camera | Forum: Poser - OFFICIAL
Wow... How do you make the bump maps from the photos? I tried once for a bodytexture, but the results were not as pleasing...
Thread: Conforming clothes to morphed body parts | Forum: Poser - OFFICIAL
Magnets should be fine if you started morphing the body itself with em (what I'm considering for Judy due to lack of physical morphs available for her)... Another opportunity in P5 might be to import the clothings mesh as a Prop, use clothing room to fit it to the new body shape, export the so shaped object, and hack the clothings CR2 to work with the exported object. Sadly clothing room has "some" (to say the least) problems with thight fiting clothes...
Thread: Quick poll for Poser 5 users........... | Forum: Poser - OFFICIAL
Thread: I'm missing teen-, muscle- and voluptous-morphs for Judy ... | Forum: Poser - OFFICIAL
I did download SP1 (it says its 5.0.2.241 now) but that only fixed the full body morphs, didn't add any new morphs on bodyparts...
And the additional szene that's on the Application-CD only adds a few face morphs...
Thread: What 3D prog do you guys use to edit Poser Meshes? | Forum: Poser - OFFICIAL
Were closing in! I obvisiously have an older importer for my 3DSMax 3.1! It only shows 2 groups, "default" and "Figure 1" when importing an .obj UVMapper reads perfectly. Sadly I don't have 3DSMax on my machine here at work, but I'll give it another shot by not exporting the "Figure Names in Polygon Groups" from Poser later at home... Thanks for your efforts so far =)
Thread: Serial Number for Downloaded Update from P5 to P6 (purchased!)? | Forum: Poser - OFFICIAL
