4 threads found!
thewardenmaster | 1 | 13 | ||
thewardenmaster | 16 | 126 | ||
thewardenmaster | 3 | 13 | ||
thewardenmaster | 4 | 19 |
6 comments found!
...seems to become my fovourite tool by the time it'll be out!!! By the way, will it still be free for private use? Best, Mike
Thread: Help! After UV Mapping in Deep Paint 3D Figure distorted! | Forum: Poser - OFFICIAL
[...] P.S.: The actual trick is to REMOVE all UV Coordinates from the original *.obj file before loading it into UVMapper and importing the newly generated *.uvs file into it. (That's what 3DSMax did at this point.) Mike
That's the way I did it: I tried to do some UV Mapping with 3DSMax, of course it didn't work, 'cos I don't know this program too good except for making morph targets. Result: All UV Mapping coords have been removed from the obj file, when opened in UVMapper to view my results, LOL ;-> ... So I had the idea, why not try importing the before saved *.uvs file from the remapped obj -> Worked Opened in Poser, everything is fine!!! Dmentia is absolutely right: UVMapper does ROCK!!! Thanks to Steve for your ultimate tool!!! All the best, Mike
Thread: NEED (more) HELP -> Transparency on Props | Forum: Poser - OFFICIAL
I did all the usual stuff: Created mapping coords with UVMapper, tried all possible amounts with the slider, no effect! I got no clue!
Thread: NEED HELP : Importing own Props -> Setting Parent | Forum: Poser - OFFICIAL
Yeah, that's it! But I still can't get the transparency to work correctly, i.e. at all, though I'm using proper transparency maps. Those are supposed to be the sting to all this, for I'm trying to create authentic eyebrows. I created them by cutting out the brows from the original face and saving them as *.obj. Is there anything that has to be considered while making them (I already did all the usual stuff -> UVMapper etc.)?
