19 threads found!
tony3d | 8 | 10 | ||
tony3d | 1 | 2 | ||
tony3d | 4 | 31 | ||
tony3d | 0 | 4 |
(none)
tony3d | 5 | 6 | ||
tony3d | 5 | 6 | ||
tony3d | 7 | 28 | ||
tony3d | 5 | 9 | ||
tony3d | 0 | 5 |
(none)
tony3d | 1 | 4 | ||
tony3d | 1 | 9 | ||
tony3d | 16 | 62 | ||
tony3d | 10 | 79 | ||
tony3d | 7 | 18 | ||
tony3d | 1 | 3 |
20 comments found!
That was it. I didn't realize I had to install the render cow on both machines. Now I save about 35% render time. I noticed it when I checked the activity monitors on both machines. Mine was around 20%, while the othe was at 100%. Thanks for all the input.
Thread: Image Sequence | Forum: Vue
When the image sequence animation starts. In Lightwave you can just tell the sequence which frame to start running on simple as that.
Thread: Video Card | Forum: Vue
Thread: Alpha plane | Forum: Vue
figured it out. If I load a 32 bit tif image sequence the alpha channel does not load, but if I render separate jpg's for the color channel and alpha channel in separate imges, I can load the alpha image sequence independant of the color. This works fine.
I did that but the problem is the first few frames are black and it does not seem to pickup the alpha.
Thread: Object export | Forum: Vue
I just downloaded it again maybe one-two days ago. It doesn't tell me I can't export it like it did before just that my disk is full when I try.
Thread: How does anyone use this software? | Forum: Vue
I think I will try to skip the multipass stuff. I have one more question for you though. I am trying a camera fly through and need to solve one other problem. The camera starts at the shorline then moves up to an over head view. I'm using smooth velocity and ease in/ease out. At the beginning I get this extra camera movement down before it begins to rise. How can I stop that? In Lightwave it's a simple fix in the graph editor.
Do you have an e-mail address? The zip file could be about 8megs!! Today I tried saving a multipass image and it worked fine on a small image. I wonder if i'm doing something wrong when I save it. First of all, can you only save amultipass image from the screen? It seems that if I set up multipass then say save to disk is when I get nothing.
Object Masks and Material masks. The file that I'm having trouble with is about 800,000,000 polys. It's about 8 meg can I send it to you?
I have rolled back ro 277255. I just rendered a single tree at 17"X11" 300dpi and it did it. I wonder if it has something to do with using multipass?
Thread: Long Render Times | Forum: Vue
Vue tries ro make UV Map for the procedurals, but fails big time. It can't even export a simple object back to Lightwave if that object was first created in Lightwave. Go figure....
Thread: Render Cow times | Forum: Vue
