4 threads found!
tsinghis | 1 | 53 | ||
tsinghis | 10 | 173 | ||
tsinghis | 3 | 65 | ||
tsinghis | 1 | 23 |
7 comments found!
I have had those too occasionally.. but very rare bug .Dont know the reason... something of resolution or texture file related.. i think cause I have done some changes to my textures and this has occurred.
Thread: wierd and troublesome problem using poser 7 | Forum: New Poser Users Help
Well well there was some bugs 6 in all in my comp after all. I removed them with Rogue removal tool and abracadabra poser quit to do that thingie.As I said my comp is not online so bug has come from one of the file i got from either here or sharecg .So folks check your comps.but Ill investigate this further still ....and thanks for comments
And thanks for comments - Ill try to figure out this- if i get solution- Ill notice you too thanks!!!!!
Well I cleaned the whole computer and its register, and Remorphed alittle figures, what i use Victoria4.2- and saved them again to poser library (after removing old ones). And cleaned also new ones magnets with python script . That script is from Phil C if i do remember correct.Results; the symptom almost vanished totally- figures are working again as they should...hmm
Also I saved a new scene file inside posers runtime file and named that to untitled. I suspected also the mouse -its bit old and its drivers so I am planning to get new mouse and try that too.Odd thing is that whole thing started few month ago ... My comp is not inline .I have habit to get files from Renderosity and Sharecg ...I hope its not a some kind of bug...Poser has worked well before hmmm but if its a poser bug then support please...
Thread: proportions?? | Forum: New Poser Users Help
Thanks for answer.. I thought that I was somehow odd...hah so Id have to up date my poser..my story.... just as i have got character right i have to update...hah hah :Actually I used weight map morph to this character it bends like dream thigh problem no existing..one question how I can upload character here?
Thread: Copy Position only: X,Y,Z | Forum: New Poser Users Help
What version do you use ? I use poser 7 and when i save the pose, Poser ask do you want to save only the place of the character and pose? or as second option morphs and placement because in default poser put character where it was when it was saved as posed.
Thread: hand "cut" | Forum: New Poser Users Help
