4 threads found!
valmik | 10 | 1441 | ||
valmik | 5 | 405 | ||
valmik | 0 | 461 |
(none)
valmik | 4 | 1236 |
9 comments found!
Hey Offrench. i saw your scene which u made. its really amazing. i completly understand the vue part which u have done. but is it possible for u to cover the Geo control part. or any other link frm which i can follow ur steps.
thanks for ur help....!!!
Thread: Vue infinite 10:my ecosystem not responding | Forum: Vue
how big is ur scene. in Previous Vue whn u load a terrain, the size of terrain by default is 256 * 256. while in VUE 10 size of terrain by default is 1Km * 1km, thus it uses hell lot of memory n time to populate. try reducing the size of terrain and then populate with very low density. if it responds well, go on slowly incresing the pop. which u wan.
do try ths.
Thread: memory ( RAM ) - used for vue rendering. | Forum: Vue
Thread: Problems with Poser importing. | Forum: Vue
ths is the setting which i think u need to keep while u import poser scene in vue.
Â
Thread: help finding model (building) | Forum: Vue
Thread: Wanted Urgently... | Forum: Vue
hey if u looking for DEM.. u should better go to site.
Â
http://viewer.nationalmap.gov/viewer/
Â
http://seamless.usgs.gov/services.php
Â
there is a whole world map.. so u can select the areas u wan to download. n use 3dem software it will b helpfull...
Thread: Flying Through Clouds Tutorials and Tips? | Forum: Vue
hey i too agree with bruno... @ **zonkerman - just keep rendering setting very low whn cam is inside clouds... n avoid using motion blur.
Thread: Rendering problem: the screen appears black! | Forum: Vue
i have faced the same problem earlier. but it is not the problem of max or vue now ur cameras,
just let me know ur pc config, which version of windows u using 32 or 64 bit?
when i faced this prob, it was because of 32 bit windows, even after having 6 gb ram n core i-7.
but when i switched to 64 bit windows, rendering worked correctly.
if u using 32 bit windows, then this problem will surely occur, bcoz ur machine wont use more then 2gb of Ram even if u hav more then that..
do have a look at ur stats, i.e... ur no. of polygons & faces... but i m very sure this prob, occurs due to win 32 bit...
Thread: HELP !!! How can i invert ecosystem attatched wit my terrain. | Forum: Vue
thanks... man.. this is what i did... painting didnt work... so i think fliping it is the only 1 thing.
thanks for the feedback..!!!
