102 threads found!
vilters | 17 | 985 | ||
vilters | 29 | 1170 | ||
vilters | 83 | 2371 | |
vilters | 15 | 695 | ||
vilters | 12 | 453 | ||
Advisories: nudity
vilters | 21 | 558 | |
vilters | 16 | 510 | ||
vilters | 9 | 535 | ||
vilters | 10 | 457 | ||
vilters | 4 | 299 | ||
vilters | 3 | 177 | ||
Advisories: nudity
vilters | 34 | 3186 | |
vilters | 3 | 174 | ||
vilters | 25 | 985 | ||
vilters | 89 | 2506 |
4,852 comments found!
Is there a "thank you" or "like" button here?
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Thread: M4/V4 in Face Room | Forum: Poser - OFFICIAL
Slingshot the object file into Blender and you have a Full Body Room.
And use projected pâinting to get a new texture.
Dev
"Do not drive
Thread: Why are you still using V4? | Forum: Poser - OFFICIAL
Hey, hey, hey, Pumeco... Cool down.
Earl started a good tread, and the simple and most common answer is : Investment in her content.
But the world does not turn around 3D, and certainly not around a single figure.
End users have options bringing ANY native Poser/DS figure into Zbrush or Blender or whatever app they use..
PS: In another tread you asked hy I did not give them away..
Well, from yesterday morning till today, 18:00; I did 132 modifications on the figure object file, and 4 modifications on the UV_Map lay-out.
=> And correct, I did NOT touch the face yet.
And YES; I use that figure all the time for testing purposes, and for the last 4 years, not a week went by, that I did not change/adapt the object file.
Working so Lo Poly is extremely difficult.
Right now, I am in object body file mode, and in procedurals mode.
Dev
"Do not drive
I only asked to read the title of this page, nothing more, mothing less.
I get warm nor cold about what figure you use, as the birds outside will keep whisling anyway.
I am gonna take a nice shower, and tomorrow will be saturday.
Dev
"Do not drive
Thread: Best way to morph "too-tight" clothes | Forum: Poser - OFFICIAL
Try this?
Put your figure and undies in Poser, put them in wireframe mode, and take a screengrab from the front, side, and rear camera.
Then put the dress on the figure, put them in wireframe mode, and take the screenrgabs.
You should now have a pretty good idea, where to "paint" your undies on the dress UV-Map.
Look ate the polygon intersections and work from there.
good luck
Dev
"Do not drive
Hey Zevo?
What does it say on top of this page?
Dev
"Do not drive
Thread: Poser Forum on facebook … Competition! | Forum: Poser - OFFICIAL
STOP adding absolutely useless things.
Fix the forum , fix the freestuff section that is now in a complete mess beyond recognition. The NEWEST freestuff item is from 2004, andthere is NO way to walk through the other items.
To add a freestuff item, one must be suicidal.
FIX what is broken before adding more broken things.
Dev
"Do not drive
Did the dress come with a UV_Map?
Then you can paint a black and white dosplacement map using the lay-out that came with the dress.
If the dress did not come with a UV-Layout you can make one using uvmapper free.
Black is no displacement and true white is full displacement.
Dev
"Do not drive
Correct, that sort of detail is best put in a displacement map.
Dev
"Do not drive
Thread: Should Vendors be forced to diversify? | Forum: Poser - OFFICIAL
Ha-ha-, correct, and if I would be that last vendor, I would have to declare that as a second income, and loose another 50%
So, from the intial 6.74 stays??? => A whopping 0.445 for each sale for each creator.....
And for that we get?
A forum that is bananas.
A freestuf section that went oranges
Now, where can I buy a Porche??
Dev
"Do not drive
Thread: New "dolls" for the "ladies" to play with. | Forum: Poser - OFFICIAL
The PoserPro series of figures initially came a LONG time ago wint a PoserPro version.
They have a seperate folder.
Their purpose is testing only.
But I have to warn you. The meshes "as they come" need a complete workover to get where I am now. And expressions and so on, are mine.
Have you not seen the "default meshes" in another post of me?
Dev
"Do not drive
And you did not see her angry yet did ya !
That's her expression when she sees the forum state, or visits the current freestuff area. What a mess;
(or when a "V" comes too close. LOL.)
PS: For the tech guys: This is a progressive render.
Dev
"Do not drive
Yes Pumeco, these PoserPro meshes (male and female, medium and Low Res) come without restrictions.
If my memory is correct, the medium resulution meshes are some 36.000, and these Lo Resolution meshes are default around some 7.900 polygons.
But what you see above is an upgraded PoserPro Low Polygon female mesh.
I have several of those, ranging all around some 8.000 to 8.300 polygons.
And I could distribute them without any restrictions.
Dev
"Do not drive
Ah, you thought they did not have expressions? Nodes?
Think again... LOL.
Dev
"Do not drive
Oh? You ladies want "male" dolls.
Euh. . . . with or without the "ON-OFF" switch?
LOL.
Dev
"Do not drive
