11 threads found!
zander | 13 | 833 | ||
zander | 10 | 313 | ||
zander | 3 | 46 | ||
zander | 9 | 254 | ||
zander | 1 | 145 | ||
zander | 4 | 124 | ||
zander | 2 | 139 | ||
zander | 1 | 95 | ||
zander | 5 | 216 | ||
zander | 2 | 155 | ||
zander | 3 | 138 |
10 comments found!
Evidently, 12 did NOT like my preferences. Re-installed without my pref. and can, now, load and see my "actor". Other than the DSON problem, it now works. Thank you all for replying.
Thread: Loading character | Forum: Poser 12
Tried altering render settings to no avail. Sigh. Probably should have tried the free trial before purchasing. Going to un then re-install without my prferences. Hopefully, that will work. Thank you for help.
Uninstalled. Installed. Nothing shows up in window, yet in the "parameters" window the specs show up. The only error msg is from the DSON importer and these in msg box. 15:03:33 - Info: Your effective UI Scale factor is 1.00 15:09:19 - Application commands: Add figure(s) from library 15:10:59 - Application commands: Set render options 15:10:59 - Analytics: Recording event for Size:1229x770 15:10:59 - Analytics: Starting timer for Render:FireFly 15:11:04 - Firefly: Number of REYES objects: 95876 15:11:04 - Firefly: Number of micropolygons created: 0 15:11:04 - Firefly: Number of texture lookups: 0 15:11:04 - Firefly: Rendering time: 4.13 seconds. 15:11:12 - Firefly: Number of REYES objects: 150383 15:11:12 - Firefly: Number of micropolygons created: 178394 15:11:12 - Firefly: Number of texture lookups: 898622 15:11:36 - Firefly: Number of REYES objects: 150383 15:11:36 - Firefly: Number of micropolygons created: 1253854 15:11:36 - Firefly: Number of texture lookups: 622001 15:11:36 - Firefly: Rendering time: 32.24 seconds. 15:11:36 - Analytics: Ending timer for Render:FireFly 15:11:58 - Application commands: Delete figure 15:14:36 - Analytics: Recording event for Library:Michael 4 15:14:54 - Application commands: Add figure(s) from library 15:16:56 - Application commands: Delete figure 15:17:40 - Analytics: Recording event for Library:D3BL 15:17:50 - Application commands: Add figure(s) from library 15:18:59 - Analytics: Recording event for Library:Michael 5 15:18:59 - Analytics: Recording event for Python:Michael 5.py 15:19:00 - Application commands: Add figure(s) from library 15:20:15 - Application commands: Delete figure 15:21:02 - Analytics: Recording event for Library:Michael 4 15:21:28 - Application commands: Add figure(s) from library 15:22:19 - Analytics: Recording event for Library:Hiro 4 15:22:46 - Application commands: Add figure(s) from library 15:23:12 - Application commands: Delete figure 15:23:21 - Application commands: Delete figure 15:23:38 - Application commands: Delete figure 15:24:16 - Analytics: Recording event for Library:David 15:24:21 - Application commands: Add figure(s) from library 15:24:37 - Application commands: Delete figure.
Intel Quad CRU Q6600@2.4Ghz 4GB RAM AMD Radeon HD 6800 series
Thread: Angelyna Wings | Forum: MarketPlace Customers
Thank you. I have since recovered this model. A friend had copied my runtime 6 years ago and still had the disc. Thank you.
Thread: "paper" textures | Forum: Poser - OFFICIAL
Thread: duplicity | Forum: Poser - OFFICIAL
Thread: massive files | Forum: Poser - OFFICIAL
Thank you..have reduced the clutter from 299 to 250 without biting my nails, pulling my hair and screaming.You're a godsend!
Thread: Libraries | Forum: Poser - OFFICIAL
Thank you so much. A fine Christmas present! Am in the process of "conversion" today. I have PBoost, but it seems to confuse Poser and me..loaded new libraries and then couldn't access them. Bummer! Your suggestions seem to handle the situation nicely. Thanks again.
