Sun, Jan 5, 4:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 1:41 pm)
Subject: Help!!! V3 morph injections?
tonymouse ( ) posted Thu, 26 December 2002 at 8:20 AM · edited Tue, 03 December 2024 at 12:24 PM
I have a 2.7 ghz sys with 1 gb of ram and plenty of hard drive space. os is Win 2000. I was trying to just inject the all expressions morph option. I let it run all night still did not finish? I was able to inject individual morphs just fine each would take several minutes. Can anybody give me some comparisons on their time to inject the all( type of morphs). I think I need to contact Daz but I thought I would ask here first. Thanks, Tony
thgeisel ( ) posted Thu, 26 December 2002 at 8:29 AM
Have the same problems on a 2 gig Athlon . Using poser 5. Several people report problems with the "all" morphs in p5 but no probs in p4.
BeatYourSoul ( ) posted Thu, 26 December 2002 at 8:34 AM
I had the same problem on a 2.53GHz P4 w/1GB ram on Win2000. Waited several minutes and ended up killing Poser 5. The All Morphs injection isn't worth it as far as I can tell. It creates a 102MB file which will be ungainly to work with on any current system. Better to inject just those necessary (or more and remove them when done). It actually takes less time and creates a much smaller file.
tonymouse ( ) posted Thu, 26 December 2002 at 8:42 AM
I agree there Beatyour soul, I was just going to use some of the Lesser alls like expressions since I am likely to use all those. I hate to have to do it all morph by morph, I still have p4 loade perhaps I could inject over there and then move the cr2 to p5?? I'll try that when I get home.
Pinto ( ) posted Thu, 26 December 2002 at 8:47 AM
1.7ghz P4 with 1gig ram. Poser 4.0. Windows XP Pro. Injecting all morphs took about 2 minutes for the head and 2 minutes for the body morphs. Loaded V3 poses and moves like V2. No problems. Must be Poser 5. Regards, Pinto
PheonixRising ( ) posted Thu, 26 December 2002 at 12:44 PM
It does take several minute to install the "All" morph files. No idea why that would happen to you. We'll look into it.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
PS: Ram should matter at all.
tonymouse ( ) posted Thu, 26 December 2002 at 1:35 PM
Thanks Anton, do you mean should or should'nt. let me know what you find out or if you need more info from just let me know. Tony
MeInOhio ( ) posted Thu, 26 December 2002 at 2:18 PM
Do you think this is caused by people installing V3 into none standard locations? Poser 5 let's you make additional runtime directories. I have one called MyPoser (for lack of more imagination at the time) under the Poser5 directory. Pratically everything in it is from DAZ. When I tried to use several of the "All" morphs, it took for ever and never actually did anything. Someone else on the forum said that if you install V3 to the Poser 5 runtime directory, that things work okay. I tried installing V3 into the default Poser 5 directory and then loaded the "all" expressions morphs and they loaded rather quickly. I think you can put V3 where you want her, but you have to edit the "all" morph poses so that they can find the morphs. I think the all morph poses reference other files. I haven't tried this yet. But it's what I understood from what I read. Kevin
BeatYourSoul ( ) posted Thu, 26 December 2002 at 2:26 PM
Could be. I installed V3 into Poser 4 and access it from there with Poser 5.
MeInOhio ( ) posted Thu, 26 December 2002 at 2:36 PM
Did you try injecting the all morphs in Poser 4. I understand they load quite quickly in Poser 4. Of course you have to use the default directory there. Kevin
Olivier ( ) posted Thu, 26 December 2002 at 2:38 PM
I do have the same "days of waiting" problem with P5 on 1.2GHZ Athlon with 768Mo of RAM, Windows XP Home. I wanted to reinstall P4 but I'll try to reinstall Vicky3 in the Poser runtime instead of Download folder... If doesn't work I'll try with Poser4... I'll let you know what happened! :) Happy new year to you!
invincible ( ) posted Thu, 26 December 2002 at 2:40 PM
I THINK KEVIN RIGHT I OPEN THE ALL BODY MORPH INJECTION pZ2FILE WITH A TEXT EDITOR AND WE CAN READ THIS : version { number 4.01 } //Begin All Body Morph Injection. // All Chest-Breast readScript ":Runtime:Libraries:Pose:!V3 Chest-Breast INJ:AreolaBig.pz2" So the pz2 file load each individually morph where they are per default so if you move them you have to edit the all injection body morph file and put the new directory for each morph inside example : replace ":Runtime:Libraries:Pose:!V3 Chest-Breast INJ:AreolaBig.pz2" with ":Runtime:Libraries:Pose:V3Morph::!V3 Chest-Breast INJ:AreolaBig.pz2" V3Morph :is the file i crated for myself and where i put all the morph for v3 so it can take lot of time to edit all the Body morph PZ2
PheonixRising ( ) posted Thu, 26 December 2002 at 7:17 PM
Ram shouldn't really matter unless your system is ancient.
MeInOhio ( ) posted Fri, 27 December 2002 at 7:39 PM
I finally got around to trying to edit some of the "all" morph poses, and they work with the edit. I have Vicki in the following directory: Poser5MyPoserRuntime...Vicki3, etc. I added :MyPoser to the front of the path line and :Vicki3 to the end. I had to edit each line. When I was done, I saved the file and fired up Poser5 and tried to load all the chest morpsh and all the ear morphs. Those were the two files I had edited. The morphs all loaded in about a minute. Kevin
