Tue, Feb 18, 4:35 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: V3 Mapping in Bryce
Great Bizarro ( ) posted Wed, 15 January 2003 at 7:43 AM ยท edited Sun, 28 July 2024 at 3:37 AM
I am having problems with the V3 obj when used in Bryce. I use the body map on the body portion of the mesh and all works well except 2 small areas to the right and left of the pubic hair area. These areas don't seem to be taking a texture from the body maps and they stay white. I can select them then set them at the same color as the rest of the texture, but this is a pain to get the color just right. Anyone else having this problem?
Phantast ( ) posted Wed, 15 January 2003 at 9:55 AM
No, I have no problems at all.
dragongirl ( ) posted Wed, 15 January 2003 at 1:05 PM
To make it easier to get the color right in Bryce, just Copy the Materials from another body part and Past Materials to the unassigned parts. This will make the all the DTE settings the same and the colors and bump will match then. -dg
EricofSD ( ) posted Wed, 15 January 2003 at 10:25 PM
Did you run it through Grouper first?
Great Bizarro ( ) posted Thu, 16 January 2003 at 7:27 AM
dragongirl, that is what my fix so far has been but the area to select from on the bitmap when you have to pick is so small in Bryce it is hard to hit just the right color. EricofSD, good idea I will give that a try Thanks All!
