Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
It happens quite a lot when you use poses dowloaded from the net. I usually : set the hair while the figure is in its default pose click "object:lock actor" open the pose library and apply the pose modify the pose till it suits me click "object" uncheck "lock actor", pose the hair. That's the best workaround I've found, but I'm not the most technical guy round here. Compiler
Actually, you missed something. There is something wrong with the poses themselves. I paid good money for them too. Apparently there was some stray info referring to hair or something. Pose creators should always use "blank figures" to create poses. Poses should be saved without any morph information as well. The only surefire fix is to create a "blank figure" for each character. The blank characters have no morphs. Create a folder and copy the poses into that folder. This gives you a backup. Apply each pose to the blank figure, then resave. Be sure not to save any morph info. Once all the poses are resaved, in their safe format, you can copy the original "rsr or png" files into your new Pose folder. Multiply this work by hundreds of poses and all your characters, and it's loads of work. Someone should create tutorials on this one.
