Mon, Feb 17, 6:47 PM CST
Renderosity Forums / 3D Modeling
Welcome to the 3D Modeling Forum
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 16 8:08 pm)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the
MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
Subject: metasequioa help
airflamesred ( ) posted Fri, 24 January 2003 at 5:27 PM · edited Sat, 27 July 2024 at 1:16 AM
having built a coffee cup model I now have to add the handle.adding and re-shaping another primitive seemmed the logical step but had trouble lining it up to the cup body withoout getting a seam.cutting and extruding faces seemed to create more problems (selection).Anyone got any other ideas?
EricofSD ( ) posted Fri, 24 January 2003 at 9:08 PM
a screen shot would help. I presume your question is not on making the handle but on positioning it with the cup?
airflamesred ( ) posted Sat, 25 January 2003 at 6:06 PM
Yes how do I align the points in red to the cup body seamlessly.The only alternative I can see is to extrude some faces and try and reshape them. Thanks eric
EricofSD ( ) posted Sun, 26 January 2003 at 4:42 AM
You might want to try the magnet tool to put a curve in that face. The magnet tool can be weighted to pull only one point or any strength beyond a single point. Then just position it and export as a single object. I think Meta tends to weld on export. The other way is as you say, extrude the faces and just sink the handle into the body. Its been a while since I've used meta. Been kinda enjoying the dvgarage thingie.
pearce ( ) posted Mon, 27 January 2003 at 6:37 AM
Remember you can select and extrude edges as well as faces, and you can use the knife tool to make more connecting points in a mesh (e.g. the cup). Also extra triangles/quads can be added with the `create face' tool, which can be used to link the parts. Finally, duplicate vertices can be merged. It's all a bit like virtual tailoring, really. M.
