Fri, Nov 22, 8:34 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Poser4MovieWithShadedHair
tebop ( ) posted Wed, 16 April 2003 at 9:06 PM · edited Mon, 29 July 2024 at 7:14 AM
Hello, I finaly found out how to create movies faster in Poser 4 by using the Using Current Display Settings, no antialiasing. This is fast, and i don't really mind if it's not full color and quality. However when i render like this Texture Maped Hair Objects appear only as dotted white, invisible hair. Is there any way to make the hair texture appear when i'm rendering in Current Display settings( current display settings renders as you see it in the document which usually has invisible hair)
Little_Dragon ( ) posted Thu, 17 April 2003 at 12:03 AM
The dots indicate transparency. The only way to display transparency properly in Poser is to render the image, so you'll have to disable the hair material's transparency settings if you want to output your animation with Display mode only.
