Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=10139&Form.ShowMessage=1258117
ziggie, That thread is NOT the answer.... but.... you happen to be asking this question at the right time because les bentley and migal have come up with an amazingly easy way of doing this. Actually, lovely lady wasn't far off the mark. All you need to do is replace the line 'prop' with the line 'actor'. So 'prop box_1' becomes 'actor box_1' This method will work with unparented props, as long as you have some kind of figure in the scene. See the linked thread for details. mactasquah: I have found that there is no cross talk issue. I have loaded the same prop in the same document several times. When I apply the mat as described above... it only affects/applies the mat to the first of the props. I guess because that prop is 'prop_1:1' I see the problem being if you did want to apply the mat to more than one of the same prop. The only consolation is that the mat settings for the first prop would be in the Surface Material box and could be esily copied for the second or more of the same prop. As for the main issue... it works GREAT... I have set up 5 different mat files including a white mat for the same prop and they all work at the click of the respective icon. ziggie
"You don't have to be mad to use Poser... but it helps"
If you have more than one of the same prop in a scene, poser names them '_1'. '_2', etc. If you want to affect multiple instances of a prop, you would have to change the MAT file for each prop number, so it reads 'actor prop_2', 'actor prop_3', etc. When poser applies a MAT to a specific actor (body part), it goes through the entire scene until it finds the actor it's looking for. I haven't tried this with props yet, but in theory, even if you apply the prop MAT to the figure, it should still only affect the prop itself, (unless the figure happened to have the same materials and body part as the prop). It's unfortunate, but as far I know, there's no way round poser's numbering system. mac
Awwww rats! You had me until #11. What would be perfect is if Poser had a wildcard symbol, any chance that may have been overlooked Probably not, but one can always hope. sigh Thanks for the info though, it's good to know!
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
{Hi Ziggie :) I think THIS Post might have the treasure you seek :) Attached Link: http://www.renderosity.com/messages.ez?ForumID=10139&Form.ShowMessage=1258117} That's what I love about this place: if you have a question, just ask. Other people will SEARCH the forum for you! Why actually spend your own time clicking the SEARCH link when other people can do it for you?
Is it possible to change the material settings of a 'prop' in PPP via the Poses folder as can be done with figures (characters/clothing)...? I would like to be able to change the texture, reflection, bump, transparency of some props with a one click approach rather than have to go into the Surface Material box every time to make multiple changes. If it is possible... could somebody please explain how it is done. ziggie
