Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 4:13 pm)
I think what is happening is when you open it in C4d you have more materials than objects...check next to the object to see how many materials are on each one....if thats the case when you export it wipes all but one material on that part of the model....to fix this use the little triangles (i'm hopeless at remembering tha names LOL) next to the part to split of the polygons so every material has its own set of polys....then to fix the probs in the left image, select polygons that butt up against sharp edges and disconect (structure/edit surface) leave the check in the box so you only disconnect the edges and not everything...hope that makes sense but if not fire back...which C4d are you on if its V7 i can look at it and sort what the problem is easier.....Steve
Why shouldn't speech be free? Very little of it is worth anything.
