Sat, Jan 25, 4:38 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: Shading corrugated iron tank
dulciepercy ( ) posted Wed, 15 October 2003 at 2:51 AM · edited Sat, 11 January 2025 at 7:09 AM
Hi, I got Carrara 1.1 off a cover disk and I'm astonished. It was immediately useful because I wanted a corrugated iron water tank. I made one by modifying a formula from Jean Pellegri's pages (link found here - merci bien) Here is the formula if anyone wants it. d=4;e=2; p=2*PI*(u-0.5); q=3*(v-0.5); z=e*q; x=d*cos(p)+sin(z*15)*cos(p)/15; y=d*sin(p)+sin(z*15)*sin(p)/15; My question is if anyone has ideas how to put shaders on it. What I want is a very rusty old tank. I would probably shade it globally with a texture map of galvanised iron. The tricky part is the rust which I want to put on only the upper side of the corrugations (or would it be the lower side - now I doubt?). I've been trying to do this with slope from the smart pack but can't work out how to blend the slope effect with a colour or texture. It would also be very irregular and spotty. Any ideas appreciated. George
falconperigot ( ) posted Wed, 15 October 2003 at 5:36 AM
Attached Link: http://home.swipnet.se/JEK/tutorial/tutor.html
This link may give you some ideas.
dulciepercy ( ) posted Wed, 15 October 2003 at 9:02 AM
seems my reply didn't get posted? Try again. The link is brilliant thanks. I'm nearly there using slope instead of elevation. That pic shows the remaining problem - the shader works fine on a sphere but on my formula generated tank it shows all the polygons. I've tried every combination of tiling and get no better. Will try again later with dirrerent textures, but if you see something obvious I'm doing wrong, give us a hoy. Thanks again George
falconperigot ( ) posted Wed, 15 October 2003 at 9:49 AM
It looks like you're using a bump channel in the shader. Try it without. Mark
steama ( ) posted Wed, 15 October 2003 at 12:07 PM
Try using elevation instead of slope.
dulciepercy ( ) posted Thu, 16 October 2003 at 2:58 PM
yes it's a bump problem. Elevation works, too, but just rusts the bottom of the tank. Thanks to you both George
