Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
P5 has a lots of memory leaks. One bad one in particular concerns all textures loaded. Even if you're not using a texture in your scene it stays laying around. P5 can't handle lots of MTs either. I have MT reduced figures that I use. That may help you. For example, doing a movie with full V2 loaded with MTs will probably cause you to belly up pretty quickly. I have created a stock V2 with a single Body MT for her shape so the only MTs she has is that Body Morph, the facial expressions and the stretch legs. I can go a lot farther between shot down and restart before I crash than with a fully loaded figure.
When I try to render to .avi in Poser 5-SR3, my PC STILL crashes and does a memory dump. Has anyone figured out a way to avoid this?
