Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Make sure you save at maximum quality. Poser defaults to something ridiculous like 25% quality. You can also save in another format, such as TIF, which will, in addition to saving at high quality, allow you to use the alpha channel for backgrounds, etc.
I always render much larger than the final image is supposed to be, that gives sharper details when I later re-size it. As an example, if you want a 800 x 600 picture, do like this: - Render to 1600 x 1200 - Save as TIFF image - Use picture editing software to re-size to 800 x 600 - Save as JPG with suitable compression
sheesh loads of things here.
Look at your shadow mapping (lights.) settings should be set shadows to around 0.150
and 1024 for the shadow mapping
this will sort out the jaggedy black shadows
rendering
render in firefly
look at the rendering properties
maximum texture resolution should be high (not 1024) I run mine at 4096 (remember the octet problem pre sp1 old timers?)
this will give as sharp a render as the texture will allow.
loads more to play with (like focus, camera settings etc etc drone drone)
play with it, learn from the tutorials that people put up from time to time.
enjoy
A hibernating Narsil
back to work
SoulTaker, make sure you render in PRODUCTION mode if you use the P5 Firefly renderer. I made the mistake of rendering in draft and it washed everything out and made it fuzzy. (Hey, I learned fast :P) And yeah, as said above, make sure the image is saved as 100% not 25% which is the default. BTW anyone else find it annoying that you can't render to disk? I mean, what's the point of watching it... you can't cancel it anyway without it messing up everything... (At least I can't) Silke
Silke
Heh actually I LIKE that you can see the progress. It has always confused me in Bryce that it just pooof becomes a file on my HD LOL At least in Poser I can SEE something is happening. And you CAN cancel it, as long as the actual render has started. I've never had any luck cancelling it while it was still adding lights or shadowmaps or objects or whatever, but as soon as the actual render is progressing, I can cancel it. It may take the computer some clicks to realize that I'm actually SERIOUS, but then... it cancels :o)
The issue of saving has been brought up numerous times: Never use Poser's native JPG saving unless you absolutely must... or if you're one of the 3 people here who don't have Photoshop or Paint Shop Pro. The best solution is to export the image as a Photoshop file: you get same alpha-channel as a TIF, but the image is in native Photoshop format. Then, use Photoshop to resize the image and then Save for Web. A setting of 75-80% is more than enough.
I am getting ready to post my 1st picture, but I am not happy quality of the jpeg (not the standard of the work) its just not sharp enough or shows the detail I want. Any help would be welcome
