Tue, Nov 19, 7:22 AM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Tip: How to mirror morphs on a non-symmetrical mesh
EnglishBob ( ) posted Fri, 28 November 2003 at 5:30 PM · edited Wed, 09 October 2024 at 7:25 PM
You probably know about Masa's MTmirror application, which will copy a morph from one side of a mesh to the other. Very useful because you have only to make the morph once. However, it requires a strictly symmetrical mesh; not just symmetrical in shape, but symmetrical in vertex placement as well. If you've done mesh smoothing with something like Amorphium (as I often do), your once symmetrical vertices will soon get moved far enough that MTmirror can't work. The answer is to use The Tailor (how did we ever manage without it?) - Make a mirrored version of your mesh; most modellers will do this easily - Make mirrored versions of the morph(s) you want to transfer - Make a temporary CR2 to point to the mirrored mesh and hold the mirrored morphs - Use this figure as the base in The Tailor, and your actual figure is the "dress" of course - Proceed as normal transferring the morphs It may sound long-winded, but it was easier than replicating morphs for me anyway. Results may not be perfect, but if not, this will at least get you most of the way there.
