Thu, Feb 20, 9:53 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 5:11 pm)
Subject: Creating a morph - please refresh my memory?
dona_ferentes ( ) posted Sun, 07 December 2003 at 7:14 AM ยท edited Sun, 09 February 2025 at 12:30 PM
Hi. I used to be able to do this - scary how quickly I can forget stuff. OK. I use magnets to warp a poser body part. I use 'spawn morph target' to create the dial. After this it gets hazy... I export in OBJ format, deselecting everything except the body part involved, right? And then I get another set of choices, one of which is 'safe as morph target.' Which boxes in that panel should I select or unselect? What's happening is that I save the morph, and can later load it - but when I do, nothing happens when I turn the dial. I'd be REALLY grateful if someone could take a moment to remind me how to do this. Many thanks, Morph
geep ( ) posted Sun, 07 December 2003 at 8:27 AM
Hi Morph, How's your target? ;=] Um, I think the song goes something like this: 1. Use magnet to deform body part. 2. Select body part 3. Spawn Mort target 4. Delete Magnet 5. Select Body part. 6. Change new Morph to 1.000 (or whatever) 7. Export body part as .obj 9. Delete Morph Target from body part 10. Select body part 11. Load morph target 12. Adjust morph parametwer dial as desired Now you have exactly what you already had in step #6. ok? ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley ( ) posted Sun, 07 December 2003 at 8:48 AM
Select only 'As Morph Target', deselect all others.
xantor ( ) posted Sun, 07 December 2003 at 10:41 AM
surely if you save as morph target then it resets the figure part to the default settings? I usually just save the part with the default save settings.
dona_ferentes ( ) posted Sun, 07 December 2003 at 3:41 PM
Dr Geep (and others), Once again you pull me out of a hole. Many thanks!! Morph
geep ( ) posted Sun, 07 December 2003 at 6:03 PM
You're quite welcome. (as always) ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
