Vue F.A.Q (Last Updated: 2025 Jan 24 7:34 pm)
Glowing materials can only be simulated in Vue. Open the material editor, under 'Effects' (last tab on the right) you will find 'Luminous material' and 'Glow'. This will create the illusion that your material is glowing... but it will not be treated as a light source (that is, the glowwill not be seen on other objects). You will have to compensate that with some spotlights if thisis what you are after...
No agiel, in Vue 3.1 there is no glow material. This came with Vue 4. This means that Vue 3.1 doesn't have this feature. You can fake it in several ways. All depends how the object looks you want to "glow in the dark". Holli, can you post a screenshot showing the object you want to glow in the dark? I will then try to explain how to do that (if possible) in Vue 3.1 Guitta
Attached Link: http://www.atomic-knights.de
Is there any way to make self-iluminated-materials in Vue (3.1) ?? Like "glowing in the dark" materials or materials to simulate little lights.
