Wed, Nov 27, 12:56 AM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2024 Nov 26 4:28 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: Neon
burgi ( ) posted Wed, 21 January 2004 at 6:16 AM ยท edited Sat, 10 August 2024 at 3:16 AM
can anyone point me in the right direction for making neon strip lights? all mine don't work. John
tjohn ( ) posted Wed, 21 January 2004 at 6:45 AM
If you're wanting to turn a cylinder into a light, I don't think that's possible. But you can turn the diffuse and ambient all the way up, turn off cast shadows, self shadows, receive shadows on a cylinder and then put several lights INSIDE it and adj the range or fall-off to get the effect you want. But I could be misinterpreting what you're trying to do. Hope this helps. John
ringbearer ( ) posted Wed, 21 January 2004 at 7:00 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1167732
Here's a thread where Clay shows how to make a neon/florescent tube light. (If this is what you are trying to accomplish).
Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
RodsArt ( ) posted Wed, 21 January 2004 at 7:14 AM
If clays' light throws to much light you could try this, as what tjohn said.
___
Ockham's razor- It's that simple
RodsArt ( ) posted Wed, 21 January 2004 at 8:12 AM
Oh...not what tjohn said, sorry. This has no lights inside.
___
Phantast ( ) posted Wed, 21 January 2004 at 10:03 AM
It's a shame that all lights have to be point sources.
madmax_br5 ( ) posted Wed, 21 January 2004 at 10:38 AM
What I do is first make a cylinder. In the material lab, change ambient color to a very very light and make the ambience value 90. Kill diffuse values. Now duplicate this cylinder, and make the diameter a bit larger (if the other one was quarter sized, this one is 50-cent piece sized) Make the ambient color the actual color of the light (not nearly as light as the last one.) Make it a fuzzy material, ambience at 80, transparency at 70. Duplicate this one again and make the diameter just a little bigger (these two outer cylinders should be closer together than to the inner smaller one.) Move the transparency up to 90. Tweak color as necessary. Add a few radial lights with similar color and you're done!
danamo ( ) posted Wed, 21 January 2004 at 9:17 PM
Very impressivo madmax!
burgi ( ) posted Thu, 22 January 2004 at 4:49 AM
mr mad, sir. you are a genius worth of a salute salutes rimmer stylee from what i have seen and read yours look perfect. thanks everyone, i'll try them all and see which is best... John
Phantast ( ) posted Sat, 24 January 2004 at 6:22 AM
It looks great madmax - but alas, you can still spot exactly where the radial lights are when you look more closely.
