Tue, Nov 19, 7:45 AM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Is this why Poser documents get corrupted?
EnglishBob ( ) posted Tue, 27 January 2004 at 5:57 PM · edited Mon, 19 August 2024 at 10:02 PM
I happened to have a Windows Explorer window open while I was saving a Poser document, and I noticed a file appeared named pzSav_filename.pz3 where filename was my original filename. This file grew in size until saving was finished, then disappeared; clearly a temporary file. I restarted Poser because I wanted to clear out the texture list, and saved my second document after working on it. This time, the pzSav_ file didn't appear. Instead, the original file grew in size. Poser was writing over it. Both these files were about the same size (~20MB). I wonder what caused Poser to make a temporary file the first time, and not the second? It seems to me that the temporary file method is safer; if anything goes wrong, the original file is likely to remain untouched. But if there's a glitch of some sort, and Poser chooses to write over the original file, it can end up truncated or corrupted. Never happened to you? You haven't been using Poser long. :) Has anybody else seen this? This is Poser 4.03. It would be interesting to find out how to make Poser always use the pzSav method, but I haven't found how to do it yet.
