Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Here's the README file from the script pack: For props and hair, set their parents to none and then make sure that the prop or hair is selected...or the script will create a mat pose file for the figure instead. Go to menu Object, Change Parent...and then just click OK without selecting anything to change the parent to none. The mat pose file is saved to your runtimepythonposerscripts folder with the filename of matposefile.pz2 Just rename it to whatever you want to call it and move it to a folder in your pose library ============================================================================ morphposefile.py This will create a pose file containing your figure's morph dial settings. The morph pose file will be saved to your runtimepythonposerscripts folder with the filename of morphposefile.pz2 Rename and move to another folder in your pose library ============================================================================ scaleposefile.py This will create a pose file containing your figure's scale settings. The scale pose file will be saved to your runtimepythonposerscripts folder with the filename of scaleposefile.pz2 Rename this file and move to another folder in your pose library ============================================================================= morph-scale-pose.py This will create a pose file containing your figure's morphs and scale settings The morph-scale pose file will be saved to your runtimepythonposerscripts folder with the filename of parmposefile.pz2 Rename this file and move to another folder in your pose library ============================================================================= If anyone wants to make a gui for this or improve it in any way....please feel free. If you want to pass this around or redistribute your improved version....feel free as well.... just don't sell it! ============================================================================= Lourdes Mercado http://www.cg-fantasy.com/ Please visit my on-line stores at: http://www.renderosity.com/ http://www.3-darena.com/ http://www.3dcommune.com/ http://www.posercity.com/
Attached Link: http://webpages.charter.net/gareee/posefilescripts.zip
Lourdes wrote some great scripts for saving a scaled body as a pose. It works GREAT,but since they aren't available anywhere anymore, I'll host them. Here's the link. To make a thumbnail for this, Load your figure, and scale x,y,z as desired. Run the script of choice. Copy the new file created by the script into your libraries/pose folder of choice. Zero your figure, and apply the pose, to see if it scales as desired. Assuming it works, pose your figure for the thumbnail, and save that new pose as "dummy". In explorer, browse to the folder, and delete the actual pose file for dummy, and rename the .png file to the same name as the pose file for your scale changes. Go back to poser, exit the pose folder, and re-enter it. you should see your deformation pose with it's new thumbnail! I'll reply to this thread with the read me from Lourde's zip file..Way too many people take way too many things way too seriously.
