Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Thanks mateo, but it's more complicated than that. The problem is that when you create a light, you also create a shadowcam with a corresponding number - Light1 + shadowcam 1, for example. If I have 3 lights in the scene, named 1, 2 and 3, then add a parented light, the 4th shadowcam doesn't seem to work. It should be called shadowcam 4, but renaming the light is doing something funny to the numbers. And I don't know why. mac
The actual numbr of the SHADOW_CAM_LITE is not relevent, and offten does not match the number of the camera. In the camera check the line "depthCamera SHADOW_CAM_LITE #", and in the light check the line "parent spotLight #" (or "parent LIGHT#"). Of course if the lights have unique names the SHADOW_CAM_LITE's should also have unique names. I find the best way to proceed when renaming lights (or anything else) is to do a globall search and replace of the name starting from the top of the file, that way you are sure to change every instance of the name in the file.
camera MySHADOW_CAM_LITE 1:1<br></br> {<br></br><br></br> off<br></br> bend 1<br></br> dynamicsLock
if the name line is deleted Poser will insert the real internal name and number, if the name line is left in it can overwrite the real name/number in the dropdown menu, and that can become very confusing.
Attached above as an example is the text of a rather cut down version of a spotLight and SHADOW_CAM_LITE in a cr2, the names have been customised by adding "My" to the front of the light and camera internal names.
hi les, I fixed it. The usual dumb mistake. I realised as I was looking at your cr2 that I'd forgotten to rename the 1st entry of the shadowcam name (in the actors block). I changed it and I'm good to go. I also discovered that the original confusion over shadowcam names is probably because, for some bizarre reason, my default light setup lists Light1, 2 & 3, along shadowcams 1, 2 & 4. Poser was renaming my parented S cam as #3, which is why I couldn't figure what was where. Ta muchly, mate. mac
You mean when you switch the light the SHADOW_CAM_LITE reverts? I hadn't noticed that till you meantioned it, but your right. Memorize does not seem to help either :( This is very strange, switching the light off seems to zero the initValue as well as the "k" value! Bum, bum, BUM!!! I guess as a workround the Intensity of the light could be set to zero rather than switching it off, but this is not very convenient.
mateo,
The reason there are no shadows is that I exported the image instead of doing a render. It's an easy way to show things in the doc window, like lights or magnets. I haven't actually set the light up yet anyway. The lamp is an figure I made a while ago, but haven't released yet, so I thought it would be good to try light parenting on. But I'm not going to use it on this. I'm building a roof garden and thought I'd add a couple of lamps to it.
les,
I have another couple of oddities. First, you're right. I tried memorize and it doesn't work. You have to manually change the k values in the cr2, then it's OK. You can switch it on/off and it reverts to the defaults, which of course, are the same settings. I also noticed that the k value in Scale has no effect, but the line
staticValue 0.55
does the same thing. In my case, setting a default of 55% Scale.
Secondly, I made a SET file for this light which seems to work pretty well. Here it is below.
version
number 4.01
light mylamp:1
on
channels
liteFalloffStart Angle Start
keys
k 0 100
staticValue 100
This was just a simple one to try changing the Angle Start. Again, you must change the staticValue or it won't work. I'm puzzled. I thought static was for animation?
The only other thing is this. When I add a 2nd figure, the same one, with parented light, I don't get a new light. The light migrates from the 1st figure and moves into exactly the same place on the 2nd one. Any idea why? Could it be because I renamed the light in the actor block? Here's what it looks like.
<br></br>
version
number 4.01
figureResFile :Runtime:Geometries:room furniture:lucelamp.obj
actor BODY:2
actor stand:2
storageOffset 0 0 0
geomHandlerGeom 13 stand
actor lamp-head:2
storageOffset 0 0 0
geomHandlerGeom 13 lamp-head
actor cable:2
storageOffset 0 0 0
geomHandlerGeom 13 cable
light mylamp:2
storageOffset 0 0.3487 0
objFileGeom 0 0 :Runtime:geometries:lights:spotLite.obj
camera mylamp cam:2
All help appreciated.
mac
"When I add a 2nd figure, the same one, with parented light, I don't get a new light. The light migrates from the 1st figure and moves into exactly the same place on the 2nd one. Any idea why?" It's not to do with the renaming. Unfortunatly this is just another case of this is how it works in Poser. There is no solution that I know of (and I have tried very hard to think of one). The problem seems to be that Poser will only tolerate one instance of "light WhateverName:#" in the document, at one time.
For anyone who's following this topic, I've just discovered a strange thing. When you save a light which is parented to a cr2 figure, it does not - repeat NOT - save the shadow and map size channels. I discovered they were missing from my figure, added them back in in cr2Editor, opened it in poser and there they were. Resaved the figure and re-opened it, and there they WEREN'T. If anyone can figure that out, I'd be much obliged, but I think it's just another poser mystery. mac
I'm using parented lights in a cr2 figure, mainly because I want to add them to the scene along with the figure without changing the existing lighting. But there's a naming problem, especially with the shadowcams. Does anyone know the exact procedure for this? Here's what I have so far. If I edit the cr2 and give the parented lights unique names, they don't affect the lights already in the scene. But for the life of me, I can't get the shadowcams to work. I tried renaming them, but they didn't appear. Any suggestions? mac
