Bryce F.A.Q (Last Updated: 2025 Feb 17 1:22 pm)
Your link doesn't work because it has 2 "http://".
Oh, and the effect you've got looks like fog, but it doesn't look wet. I'm coming up blank on a fix for that. All in all, a very good image, though.
I don't know how you would achieve it other than in postwork, but when my windows fog up--other than in the bathroom--after awhile, there's drips and trails of drips. Something that might make this more realistic would be to have the foggy part only at the bottom. Again, when mine fog up, unless there's something against the window, it's usually from the bottom up. As far as making it look more like the window itself if fogged up, maybe use a mat that's something like frosted glass? One preset I'm fond of using is Shrink Wrap in the complex FX section. I'll make a duplicate of whatever and very, very slightly enlarge, then use this and tweak it to my satisfaction. 'Course, I usually do that when I want something to look smudgy, not frosty.... Hummmmm.... Maybe I can't offer any good suggestion either! :o)
Attached Link: http://http://www.renderosity.com/viewed.ez?galleryid=628487
In my last picture I tried to convey the dampness/cloudiness that builds on windows by using a cloud texture applied to a flattened cube. However I get the feeling that it looks more like the clouds are inside the room, rether than on the window. Could someone suggest any alternative ways for getting the effect I wanted? vvv in tw
