Forum Coordinators: Kalypso, Anim8dtoon
Carrara F.A.Q (Last Updated: 2026 Feb 15 8:54 pm)
Visit the Carrara Gallery here.
Thanks you very much Wilf, greatly appreciated. The next question is, are the teeth actually attached to the jaw? If you plan to make the mouth animatable or are they just placed and let the grouping to the upper and lower jaw do the trick? If they do need to be attached was an easier angle of approch then attaching then vertex by vertex? Serge
I don't know how to link an image to an ongoing thread so see "Someone Please Help" below. This is an image of some teeth I created in the spline modeler. It takes about 5 minutes to do (1.5 min to turn the machine on & launch RDS). Just set the extrusion to "pipeline" with a "free" envelope. Create elipses on 1st cross section then make 2 more cross sections, one in middle & one on end. Go to last section & scale down the elipses. Go to middle section & delete the 3 in the center. Then just play with the envelope lines to your likeing.
