PandaPride opened this issue on May 05, 2004 ยท 6 posts
PandaPride posted Wed, 05 May 2004 at 8:39 PM
Anyone know? I've been trying but no luck! please share! thanks---Essie
Tashar59 posted Wed, 05 May 2004 at 9:58 PM
kuroyume0161 posted Wed, 05 May 2004 at 10:03 PM
It is either 'built-in' to the texture (glossy appearance in the texture image) or you could try applying a reflection texture to just the lips. Problem lies in whether the lips of the model are a separate material. If not, this will not work (as expected).
off.
-- Bjarne
Stroustrup
d-larsen posted Wed, 05 May 2004 at 11:00 PM
If you are using Poser 5, there's a wet look tutorial available. I believe it was at the Curiouslabs website under tutorials. You might also search this forum for the keywords wet or wetlook. I'm sure somebody has shared other ways that might work for you.
TrekkieGrrrl posted Thu, 06 May 2004 at 1:49 AM
In Poser 5 you can add a glossy node to the Alternate Specular.
ENGELKEN posted Thu, 06 May 2004 at 7:09 AM
