Sat, Jan 25, 5:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Poser & Deep UV 2.00
d4500 ( ) posted Tue, 11 May 2004 at 3:14 PM ยท edited Sat, 11 January 2025 at 8:58 AM
Is anyone using Deep UV with Poser? Is it easy to use (UV) and does it come with a printed manual or do you have to use the one on the CD?
DCArt ( ) posted Tue, 11 May 2004 at 4:43 PM
Deep UV has some issues with Poser files; however, they are easy to get around. First, because Poser scaling is so small, the meshes appear to "blow apart" when you try to relax them in Deep UV. The way to get around this is to bring the object you want to UV map into Poser and scale it up by 10 or 100 times its original size. Export the large OBJ file and use that to create your UV map. Then, using UV Mapper, you can apply the UV map from the larger object onto your "real" Poser OBJ file. Another thing that Deep UV doesn't seem to like is groups ... so the best time to UV map your objects in Deep UV are before you assign groups to them. As far as the manual goes, I did receive a printed manual with my original purchase of Texture Weapons (which is now Deep UV) - but when I upgraded I only got the electronic version of the manual.
d4500 ( ) posted Tue, 11 May 2004 at 10:03 PM
I can't imagine paying that price and then getting an e-manual. Printed books are Sooooooooooooooooooooooooooooo much better to learn from... especially when you have a problem or run into one. Thanks.
