Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 8:30 pm)
I have not run the experiment, but selecting "universe" may be necessary to keep the figure located where it was when the pose was saved. Another tip: do your poses on bald models. Otherwise, just make sure that the hair prop is not saved with the pose. A pose will work with that same hair prop just fine, but use another hair prop and strangeness happens.
I am sure there is a simple answer to this question but I can't figure it out so I need HELP...How do you save a pose to a library so when you use it again it loads the pose in proper relation to the ground plane? Mine end up anywhere and everywhere but where they should...Thanks
