Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
Here is the procedure in poser5 Open the grooping tool. Put the display mode into "wire". In the grouping tool select "new group". Name it "ceiling" for instance. Select a part from the ceiling with no lights in it. The border of the ceiling should be then lit in red. If you accidentally select a light, just hit the "remove all button" Hit the "spawn props" button, and you now have separate props in the hierarchy deitor, named : celilng uv 1 : this is the original ceiling : hide it ceiling : your new ceiling light, light line and light line 2 : these are the light : hide them. Et voil (just tested this as I wrote along, so it should work if we are speaking of the same class prop...) Hope this helps.
For anyone who's tried it with success..... Is there a way to delete the ceiling light props and retain the ceiling only? I couldn't figure out if the ceiling is a group of props or one unit tho there seems to be 3 elements in the group. Thnaks again.......
