Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
EB, thanks for the fast response. I am taking the pose files and putting them in the camera folder. I convert the pz2 file to a cm2 file by retyping the extension. Then I apply the pose to V3 or whatever character the pose is for and if the file only has a png. I try to add (+) it to the library so I can get a rsr thumb to go with my cm2 file. Like I said I have no problems saving poses in the pose folder like this to make a rsr file just seems to be a problem in the camera folder. In other words I apply a face injection pose then save it to the camera library as the same name the png was and it makes and rsr. But when I try to use the rsr file by clicking on it to apply the pose later it doesn't apply it.
That is probably because when you save your image you are overwiriting your pose file (masquerading as a camera file) with a camera file - You can't save pose files directly to the camera folder and you can't save a thumbnail (using the + in library folder) without overwriting the file. Even if you used a pose file to pose the figure that you rendered, resaving it to the library to get the rsr will destroy it. If you want a thumbnail just set your render options to render to a new window that is 91x91 pixels then save that as PNG to the camera folder with the same name as your pose. I use p3DO for converting PNGs to RSRs (and vice-versa)- it sure makes the process easier :-)
Attached Link: http://www.senosoft.com/
What Ron said. :) Don't write MAT poses back to the library, because they're not an 'official' Poser file type. If you save into the Pose library, you get a straightforward pose file; and if you save into the camera library, you get a camera setting - nothing like what you intended. I second Ron's recommendation of P3dO also. You can get it free at the link. Yarp doesn't give me anything for saying this - he'd be broke by now if he did. :)There is something odd about .png files in Camera folders - they don't support transpancy (whether created by poser or by a 3rd party app), probably as a result of the forced viewfinder graphic addition that EnglishBob mentioned. That's why the Daz Bump graphics look all weird if you move V3, M3, etc. pose files to a Camera folder. So the 2 fixes are as mentioned, PDO or do it the pose folder before the transfer.
Hi Folks, Im converting some simple inject remove poses to the camera folder in Poser 4. The cm2 conversion of the pz2's works fine. I am however having problems trying to resave the files from the png's to rsr's. It seems that the poses won't work unless I leave the ol shrugging guy png's alone and don't try to save a new rsr for the files. Is this a problem with the camera folder? I never had problems saving rsr's from png's in the pose folder? Any advice is appreciated.
