Sun, Feb 16, 5:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Parameter Settings - Can you set Sensativity default to 1 so that it stays????
shadownet ( ) posted Fri, 11 June 2004 at 12:52 PM · edited Sat, 10 August 2024 at 8:32 AM
Hi, trying to set limits on a prop. Basically, I want the morph either on or off. O or 1 so I set the min to 0 and the max to 1, and I set sensativity to 1. Everything works just right. Then I save the prop to the library. When I load it back. Poser changes the sensativity setting to 0.00012 Okay, so I look in the pp2 and find a line called trackingScale and it shows this same value 0.00012 I change it to 1.00000 and think that will do the trick, but darn if when I load the prop again, the sensativity is still at .00012 What am I missing here???? Thanks in advance
PhilC ( ) posted Fri, 11 June 2004 at 1:24 PM
Yes I've come across this also and not found a direct answer. Here is another idea however. Load up the Poser 2 Lo Casual Man. Select his hand and turn the "Hand Type" dial. It switches the hand geometry to give different hand poses. Point being that the dial settings are integers. Open up the CR2 in your editor and look at the coding.
I tried editing the extra "uniqueInterp" and "interpStyleLocked 1" lines into a morph channel but they did not help. The "forceLimits 4" line is there to force limits to be turned on for this channel.
If I think of anything else I'll post.
shadownet ( ) posted Fri, 11 June 2004 at 1:41 PM
Thanks Phil. I thought of geometry switching, but really all I needed here is a morph on or off. Though I see where you are suggesting something a bit differently here. I have played around with a few dial settings, but apparantly there is something internal in Poser that makes it default to this value. I have tried changing 1 to lesser values .00032 in the cr2 but the .00012 keeps showing up. Yes, let me know if you think of something else. Maybe someone else will have a handle on this one....
maclean ( ) posted Fri, 11 June 2004 at 2:17 PM
shadownet, I've tried everything under the sun to set tracking values and poser always resets them. I was going to suggest the same thing as phil - switching geom. mac
shadownet ( ) posted Fri, 11 June 2004 at 2:24 PM
Thanks mac, looks like it is just another of them there Poser things.
lesbentley ( ) posted Fri, 11 June 2004 at 4:36 PM
I don't know a real solution to this problem, it seems to be another hard coded "feature" Of Poser.
I do have a partial workround. Hide the targetGeom channel and slave it to a valuParm channel. trackingScale works ok for valuParm channels. The main reason this is only a partial workround is that if two instances of the prop are loaded you will get crosstalk. Anyone know how to make a NULL Prop?
      channels<br></br>            {<br></br>           valueParm <br></br>                       {<br></br><br></br>                     initValue 1<br></br>                 hidden 0<br></br><br></br>                      keys<br></br>                                {<br></br>                           static  0<br></br>                           k  0  1<br></br>                             }<br></br>                   interpStyleLocked 0<br></br>                 }<br></br>           targetGeom Morph<br></br>                    {<br></br>                   name Morph<br></br>                  initValue 0<br></br><br></br>                       forceLimits 4<br></br>                       min 0.000<br></br>                   max 1.000<br></br>                   trackingScale 1.000<br></br>                 keys<br></br>                                {<br></br>                           static  0<br></br>                           k  0  0<br></br>                             }<br></br>                   interpStyleLocked 0<br></br><br></br>                       indexes 413<br></br>                 numbDeltas 486<br></br>                      deltas <br></br>                             {
shadownet ( ) posted Fri, 11 June 2004 at 4:41 PM
Hi Les, I was just playing around with ValueParm trying to do exactly this same thing, but was not hitting on the right combo. Thanks a bunch, you saved me some big time headache. From the looks of it, it was the NO_Fig giving me problems. I was inserting Prop NameofProp here. Where you have box_1 I was listing just the name of the prop. I will give this a try. Thanks again. :O)
shadownet ( ) posted Fri, 11 June 2004 at 5:13 PM
Les, that did the trick, all except I can not seem to get Poser to hide the targetGeom morph. Am I doing something wrong here or is this something along the lines of you can not hide a morph in use????? Seems I vaguely recall reading something like that????? No real problem. I ended up using pose files to turn the morphs on and off. But this looks like it could be useful to know down the road, so I am curious if that unneeded dial can be hidden or not. ------------ channels { valueParm Master { name HideSword initValue 1 hidden 0 forceLimits 4 min 0 max 1 trackingScale 1 keys { static 0 k 0 1 } interpStyleLocked 0 } targetGeom NoSword { name NoSword initValue 0 ------------> hidden 1 forceLimits 4 min 0 max 1 trackingScale 1.000000 keys { static 0 k 0 0 } interpStyleLocked 0 valueOpDeltaAdd NO_FIG elfscabbard_1 Master deltaAddDelta 1.000000 indexes 1296 numbDeltas 21724 deltas {
shadownet ( ) posted Fri, 11 June 2004 at 5:14 PM
Oh, btw, I inserted the --------> in this post to point out the hidden 1 line. It is not coded with that in it.
lesbentley ( ) posted Fri, 11 June 2004 at 6:28 PM
Sorry Shadownet, my mistake. I should learn to test my code before posting.
Put the "hidden 1" after the deltas, just before the closing brace for the channel:
                         d 482 0.001288582 0.001610726 -0.001288582 <br></br>                         d 483 0.0005705655 0.0008558482 -0.0005705655 <br></br>                              }<br></br><br></br>                      }<br></br>           xOffsetA originX<br></br>                    {<br></br>                   name GetStringRes(1028,44)<br></br>                  initValue 0
lesbentley ( ) posted Fri, 11 June 2004 at 6:34 PM
P.S. If you save the prop from the Poser interface back to a pallet the "hidde 1" after the deltas will be stripped out and the dial will show again.
shadownet ( ) posted Fri, 11 June 2004 at 6:38 PM
LOL, not a prob. I appreciate you taking the time to help me on this. I figure this will be a good trick to know, so I wanted to get it working right in my sample copy so when I can use it as a template down the road. :O)
